Date/Time: Sun, 16 Mar 2025 00:00:21 +0000
This message does not stop in my log file / version 2417 latest
View Count: 629
[2022-07-20 23:12:44]
User200390 - Posts: 31
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:08.961
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:08.961
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:08.993
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:08.993
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.022
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.022
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.076
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.076
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.105
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.105
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.133
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.133
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.162
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.163
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.192
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.192
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.230
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.230
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.264
File compression enabled. S:\SierraChart\Data\TICK-NYSE.scid. CompressionState=0 | 2022-07-20 19:11:09.264
Enabling compression for file: S:\SierraChart\Data\TICK-NYSE.scid. This may take a while. | 2022-07-20 19:11:09.295
[2022-07-20 23:21:11]
John - SC Support - Posts: 38678
If you are running the software using an emulator on a MAC, then we recommend setting the compression for data files to "No Compression". Refer to the information here:
Sierra Chart Server Settings: Use Real-Time Data Compression (Global Settings >> Sierra Chart Server Settings >> General >> General)
If you are not on a MaC, and if you have a chart open for TICK-NYSE, then select Edit >> Delete All Data and Download. This will remove the file and then redownload the data. Let us know if this resolves the issue.
[2022-07-21 00:04:53]
Running on Windows 10 no emulation. I set the real time data compression to false and did delete all data and download, reconnected to the data feed and no change. Restarted SC and no change, still logging that event continuously.
[2022-07-21 03:29:57]
This is very unusual.
We need to see the entire Message Log.
Restart Sierra Chart and when you start seeing the message provide the message log:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-07-21 13:16:16]
Submitted the log thanks
[2022-07-21 14:59:44]
We called and left a message. This is not making any sense to us.
We can see how there could be a scenario when you disable compression it is not actually getting disabled. We will put out a new release to resolve that but you should not be getting the message repetitively. That indicates, that particular file (S:\SierraChart\Data\TICK-NYSE.scid ) is getting opened over and over again and we do not know why. Would you know why?
And what type of storage system is this? It does not support compression.
[2022-07-21 20:48:17]
Sorry I missed the call so many thanks for following up. The issue may be the storage; this is run from a CIFS share on a NAS. It also could be getting opened in some sort of circular loop I will check with Kim Hemmes who built the indicators the chart is using. It could be a study that is causing it as I have the same instrument on a chart in another workspace that does not have this error; it only occurs on that other workspace.
[2022-07-21 23:06:24]
OK here is what I found via trial and error. Removing this embedded study stops the logging loop.
It is not letting me paste the image in this message box so I am uploading it. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=67078
Private File
[2022-07-22 08:54:31]
Ok that is good. We thought it would be something like that.
Wait for the next release to be able to disable compression.
[2022-07-29 21:18:17]
Is there a new version that supports the compression?
[2022-07-29 21:31:14]
Do you mean supports disabling compression?
[2022-07-29 21:35:29]
Yes to resolve the issue with the logging of the tick data file
[2022-07-30 10:31:02]
Update to the latest release of Sierra Chart:
You can disable compression through Global Settings >> Advanced Service Settings.
