Date/Time: Sat, 15 Mar 2025 07:51:02 +0000
Learning SC via Utilize Simulated Trading Service or Chart Replay w/ New Account
View Count: 399
[2022-07-20 00:45:47] |
DoraW - Posts: 3 |
Hi SC Support, I just created an SC account and am looking to learn the product along with the SCSF API to code a test a few study/indicator ideas to see if SC can work for my needs. Based on my initial review of available documentation, there appears to be a Simulated Futures Trading Service that would be very helpful to this learning and discovery process. Simulated Futures Trading Service In trying to follow the directions in the Setup Instructions sections of the above URL SC application states that SC->Global Settings->Data/Trade Service Settings->Current Selected Service (list)-> Trade Evaluator - Delayed (Not enabled on package). Trade Evaluator (Not enabled on package) is the same, but the documentation notes that this selection requires a real-time data feed. Is such required for the Delayed Trading Evaluator as well? If not, would it be possible to get this enabled? If not possible, could chart replay post a 15-day trial work to support learning and discovery efforts to continue? Replaying Charts In this learning and discovery phase, I don’t need actual or live market data and market data via simulation and/or replay will meet the above noted learning and discovery needs if such is possible post trial. If all works out, then the next step would be to sign up for a paid license plan to use SC in an active trading environment with near real-time data streams, but I'd like to prove things out prior to moving to this stage if possible. Thanks for your response and support. Dora |
[2022-07-20 06:18:48] |
We have activated your Sierra Chart account. The Trading Evaluator services are now active for you. Trade Evaluator (Not enabled on package) is the same, but the documentation notes that this selection requires a real-time data feed. Is such required for the Delayed Trading Evaluator as well? You do not need real-time data for the Trading Evaluator Delayed service.You should not have a problem replaying the existing data you have obtained during a trial or paid account, without a paid account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
