Date/Time: Sat, 15 Mar 2025 07:56:01 +0000
lost everything
View Count: 498
[2022-07-18 21:41:11]
User411320 - Posts: 303
hello, I did a normal update on my laptop and when I opened Sierra CHart, everything was gone. How can I get it back
[2022-07-18 22:54:40]
John - SC Support - Posts: 38678
We first need to understand what is happening. Are you unable to open a Chartbook, or are there no charts in the chartbook, or are you not getting data?
What was the version you were running previously? If this was a large jump in releases, then it is possible that your chartbook is not compatible with the current version. Refer to the information here:
Chartbooks (Workspaces): Opening Older Chartbooks
Depending on what is occurring, you can also access backup chartbooks. Refer to the information here:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2022-07-18 23:07:19]
The data and chart books are working fine. The issue is that I did a routine windows update and now all the edits I made to the chart book are gone. It’s as if I just opened the account
I tried the the backup option you provided and no "data" is in the back up folder
Date Time Of Last Edit: 2022-07-18 23:16:16
[2022-07-19 08:59:09]
There must be backup files in the backups folder. Refer to the documentation here:
In your case the folder is:
C:\SierraChart\Backups
Is that folder completely empty?
[2022-07-19 16:43:15]
you're right , there was back up files. but of the example chartbook that I started with account creation and some that I downloaded but not the one I was working on.
[2022-07-19 17:47:02]
Backups are automatically created so we do not know what happened to the file.
Check that folder again. The Chartbook filename will begin with a number.
[2022-07-20 19:12:47]
what can I do to avoid this from happening again?
[2022-07-20 19:27:19]
There is nothing you need to do normally.
Backups are maintained automatically. If backup files are getting deleted for some unknown reason we would have no idea why.
You should make additional backups by periodically backing up the entire Sierra Chart folder.
Date Time Of Last Edit: 2022-07-20 19:27:25
[2022-07-21 18:05:05]
How can I back up the entire sierra chart folder ?
[2022-07-21 19:15:52]
Just copy the entire folder to a save location on a separate disk (or removeable drive). Just make sure Sierra Chart is not running at the time. It is your choice on where to store the backup copy(ies).
[2022-07-22 07:40:29]
Sierra_Chart Engineering - Posts: 18789
Refer to:
Software Download: Making a Backup of Your Sierra Chart Installation
