Date/Time: Wed, 01 May 2024 17:16:52 +0000
Help
View Count: 2034
[2013-04-27 15:21:13] |
User86907 - Posts: 18 |
Is it possible for a study that let's you feed one study output as an input to another one. Instead of just overlay studies. Thanks |
[2013-04-27 15:51:28] |
Sawtooth - Posts: 3987 |
You can set the Based On to the other study.
[2013-04-27 17:26:47] |
[2013-04-27 21:48:55] |
Please refer to the "Based On" Study setting documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-28 00:44:38] |
Thanks again, I had another question concerning draw vol. profile. I wanted to know if it's possible to just display/configure bid side alone and to display ask side alone. I currently configured bid/ask splitting and setting one at neutral color to display the other and vice versa. This works for me but wanted to know if I can eliminate one side to display. When viewing profile with bid set at neutral color to view ask activity. Visually its a hindrance. If there's a better way around this please advise. Thanks |
[2013-04-28 07:06:58] |
Both the Bid Volume and Ask Volume and each Volume Profile Volume bar will be drawn. However, you could set one of them to the chart background color, kind of like what it seems like you have done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-29 07:56:53] |
Yes the this is what I currently do, thanks anyway.
