Date/Time: Sat, 15 Mar 2025 02:39:40 +0000
Package
View Count: 391
[2022-07-11 17:01:06] |
User768220 - Posts: 2 |
Hi I need realtime data for SP500 and DAX and also i need to use number bars, market depth, large volume indicator and delta. I don't need to connect to any broker. Which package do I have tu buy? Thanks |
[2022-07-11 18:57:31] |
John - SC Support - Posts: 38678 |
We need to verify which data you want. Are you wanting the CFD data, hence the symbols would be SPX500 and GER30? Or are you wanting the Futures data for the S&P 500 from the CME Group (ES) and the DAX from EUREX (FDAX)? Note that if you are wanting the Futures data, that you need to have a live, funded, futures trading account in order to get the much lower priced, non-professional exchanges for the CME Group. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-11 19:28:30] |
I want the future data. A live funded, future trading account means that I need a subscription to Interactive brokers for example? Thanks |
[2022-07-11 21:28:44] |
Yes, that is correct. And since you are wanting the Futures data, then you would need to have a live account that you can connect your Sierra Chart to, in order to get the data for the S&P 500 Index (ES). If you want to put a minimum amount of funds into an account in order to be able to get the data from the CME Group, then refer to the following: Easy Solution to CME Funded Trading Account Requirement Again, the above is only necessary for the data from the CME Group. EUREX does not have these requirements. Once you have the above worked out, then you can setup the Denali Exchange Data Feed. Refer to the following instructions: For the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For EUREX: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* -- In terms of the package, you will need to be on one of our Integrated Packages (10, 11, or 12) and since you say that you want the Numbers Bars, that means you need to be on Package 11 or 12. Refer to the differences in these packages here: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
