Date/Time: Fri, 14 Mar 2025 22:25:08 +0000
Study Overlay
View Count: 480
[2022-07-06 19:24:57]
User841161 - Posts: 260
I am using Study Price Overlay in chart #4, to overlay chart #1, and chart #2 onto chart. In chart #1 and #2 I am using Percent Change Since Open Study to chart percent change for day. Chart looks correct, but writing the correct values in y axis on chart #4, for scaling I have used automatic for the chart and all its studies.. If I change one of the multipliers in study to try and correct decimal place in messes up scaling for chart.
imageIndexOverlay07-06.png / V - Attached On 2022-07-06 19:24:50 UTC - Size: 226.26 KB - 118 views
[2022-07-06 20:01:17]
John - SC Support - Posts: 38678
What you are stating makes sense. The scale of the chart goes from +3.00% to -1.00%. As such, if you change one of the lines to have values outside of this range, then the scale is going to adjust in order to fit those new values in it.
On the other hand, if the values with the multiplier are what you need, then it may be more correct to have the scale showing in that way, as that is what the data really is.
[2022-07-06 22:14:36]
Actually don't need values with multiplier. Values are 1.11% and -.41%, seemed to be overlaid on the chart correctly but values not shown on y axis correctly(.01,-.0). Wanting to try getting values to be written correctly on the chart..
[2022-07-07 16:22:48]
If you need more decimal points then change the Value Format for the study. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Value Format
