Date/Time: Wed, 23 Sep 2026 21:47:23 +0000
Duplicate Chart
View Count: 1039
| [2022-06-28 22:19:51] |
| User379557 - Posts: 37 |
When you duplicate a chart does that link the charts? If yes, how can I unlink the charts? It seems when I do certain studies on the new duplicate chart it changes studies on the other charts. thank you.
| [2022-06-29 14:20:40] |
| John - SC Support - Posts: 47994 |
It only "links" the charts if the original chart had a Link Number and linking options setup. In that case, when you duplicate the chart, the link number and options are carried over to the new chart and the two charts will be linked based on the setup of the original chart. Since you mention Studies changing, then that implies that the link option for Studies is set in the original chart. For the information on Linking, refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
