Date/Time: Fri, 14 Mar 2025 17:58:02 +0000
Bids and Asks on the Chart DOM buy and sell columns
View Count: 486
[2022-06-28 19:14:17] |
MeowthTradez - Posts: 44 |
I'm having a hard time figuring out how to show bids and asks inside the buy and sell columns in the chart DOM. When I create a new trade DOM it shows the bids and asks inside the columns where you click to place your orders but my chart DOM doesn't have them.
[2022-06-28 19:45:04] |
John - SC Support - Posts: 38669 |
From what you state, you must have the wrong columns displayed in the Chart. Select Trade >> Customize Chart/Trade DOM Columns and ensure you have either of the following columns displayed: - Bid Size/Buy Column and Ask Size/Sell Column or - Bid Size and Ask Size Refer to the following information for customizing columns Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) -- If you do not have any columns showing, then you need to select either Trade >> Trading Chart DOM On or Show Market Data Columns. Refer to the following: Trade Menu: Trading Chart DOM On (Trade menu) Trade Menu: Show Market Data Columns (Trade menu) ----------- Separately, our servers are showing that you are using the Teton Order Routing Service, but you are not setup to get any real-time data from our Denali Exchange Data Feed. This would mean that you are using delayed data. In order to get the real-time data, you will need to go through the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-28 19:50:58] |
That did it! ty
