Date/Time: Fri, 14 Mar 2025 07:02:34 +0000
I can't connect to Gain capital
View Count: 476
[2022-06-17 12:53:28]
natanibz - Posts: 139
Hello, I can't connect to Gain capital, but the connection works on the OEC Trader platform. I use Denali data feed. Thanks
[2022-06-17 13:10:31]
We do not know why there is a problem. Gain Capital has been notified of the issue. There have been no changes on the Sierra Chart side and we would not withdraw support for gain capital in existing versions of Sierra Chart, only newer versions. As of yet, no change has occurred from our side.
Gain Capital should resolve the problem shortly we expect.
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2022-06-17 13:10:41
[2022-06-17 13:42:45]
Stage 5 Trading - Posts: 155
Hi Trader,
Please try connecting your Sierra Chart to the GAIN Production Account again. We believe that the issue has been resolved.
Let us know if you have any issues.
Thank you and have a great weekend!
Anthony Giacomin
Stage 5 Trading
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
[2022-06-17 13:43:55]
StoneX Futures Support - Posts: 8
The issue is resolved.
For any questions, reach out to GFSupport@StoneX.com.
