Date/Time: Thu, 13 Mar 2025 00:59:18 +0000
IDK what I did.
View Count: 362
[2022-05-31 19:28:42] |
User501925 - Posts: 3 |
I had to reinstall Sierra and I use CQG data feed. I'm stuck. It says the CQG WebAPI (Not Enabled). IDK what to do. Please help me.
[2022-05-31 22:36:56] |
John - SC Support - Posts: 38621 |
We see that you are currently on Package 11, therefore you should not be seeing that message. If you are still having an issue, then the most likely scenario is that you are logging into your Sierra Chart software with the wrong Account Name. We see that you have a total of 3 accounts associated with the same email address. The only active account is the same one you logged into this support board with (the Account Name looks like the following - AC****20). Refer to the following for how to login to your Sierra Chart with a different account name: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
