Date/Time: Tue, 04 Nov 2025 11:13:55 +0000
Autohide Numbers Bars
View Count: 497
|   [2022-05-29 20:05:00]     |
| User690917 - Posts: 4 |
                Im reposting a question from a guy before, who was neve rrepleyed, but i think this would be very intresting  Hi, It's quite a struggle right now as having to chose between number bars and more traditional candle or bars views. Sometime there is need to have global overview of chart, and for this I find simple candles are better. On other occasion there is a need for detailed view of what is going on, and in this case number bars with profiles and all is more appropriate. I really miss this feature form another software: upon a certain zoom level (user defined as for example bar pixel width) we would see number bars. When zooming out back past the threshold: back to simple candle. This would allow very rapid and natural switch between the 2 kind of views without needing a separate chart.  |
|   [2022-05-31 15:40:42]     |
| John - SC Support - Posts: 42737 |
                There is no support for this. You can always hide and unhide the Numbers Bars study to turn it off and on. Or you can load different Study Collections. Refer to the following: Study Collections: Quickly Clearing All Studies from a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
