Date/Time: Thu, 13 Mar 2025 01:08:05 +0000
how did connect CME trading datafeed
View Count: 669
[2022-05-27 05:47:42]
User359273 - Posts: 26
As i reading the sc important notice ,i know that the engineering is busying on SC development , but i am as a customer,only requirement is quickly to connecting my trading account.so i want to get help how to connecting my CME trading like before.
1 According the indicate i finished the document sign and seting by step buy step. the result is disconnect my trading account. so can give me a detail instruction
like :1:Global setting Current selected service which do i selected
2:Common setting what do i need to do
3:Sierra Chart Sever Settings how do i set for
anyway i just want to get the normal useing as like before.
before version is not my setting, as my friend is gone, i am a new operation as i used SC more than 5 years.
[2022-05-27 07:16:51]
We can see you are using Interactive Brokers so you do you have an account with them?
This does indicate a successful connection:
| Verified trading account ending date: 2022-06-18
Here are the detailed instructions to connect Sierra Chart to Interactive Brokers:
Interactive Brokers Trading Service: Setup Instructions
Let us know if you need more help.
Date Time Of Last Edit: 2022-05-27 07:17:14
[2022-05-27 07:28:17]
I think may have some mistake with the conversation
i have an account with Dorman trading,and i buy the :   10 - Standard + Denali Data Feed (For 6 Months) - 172.8 USD / 6 Months.
now i cannot connect my trading account, so i want to know how to setting, that can be connecting my trading account.
1:Global setting Current selected service which do i selected ?
2:Common setting what do i need to do ?
3:Sierra Chart Sever Settings how do i set for ?
[2022-05-27 14:06:42]
John - SC Support - Posts: 38621
What order routing service are you using with Dorman - it sounds like you are probably setup with CQG, but let us know for sure so we can point you to the correct instructions.
[2022-05-27 14:37:40]
i ask the broker, the order routing service is CQG.
so please give me the indication of correct instructions.
Thanks.
[2022-05-27 15:39:04]
Thanks.
[2022-05-27 16:03:09]
Follow the instructions at the following link to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
[2022-05-29 15:33:58]
John, many thanks to your help and below have some question i need to solve.
1:Message log show: chartbook sharing: Disconnect from the server chartbook sharing: Data feed disconnected from the server
2:when i click the file and open chartbook, which i used to be using. The range bar is not display. also the TPO and market deeps are not display. Screen is blank of range bar, TPO and Market deeps.
Based the above question, should i need Active the below:
1 Full CME Group Active 33USD/month yes or no
2 Full CME Group for nonprofessional Trading accounts 3.5USD/month option
3 CME non-professional top of book 1.25usd/month option
4 CME with Market Depth for nonprofessional Trading account 11USD/month yes or no
Private File
Private File
[2022-05-31 15:32:04]
First, we need to see your message log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Second, with regards to the exchanges to activate, you have activated more exchanges than you needed. If you want Market Depth for all symbols traded on the CME Group, then the one exchange for Full CME Group with Market Depth for Non-Professional Trading Accounts is all you need. Deactivate the others.
If you want some other combination of data, then let us know what you want and we can tell you which exchanges you need and do not need.
[2022-05-31 15:42:15]
Software version: 2394 64-bit | 2022-05-31 15:39:57.002
Primary Thread ID: 10296 | 2022-05-31 15:39:57.002
Usage end date: 2022-11-25 | 2022-05-31 15:39:57.002
Enabled for: Sierra Chart Historical Data Service. | 2022-05-31 15:39:57.002
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-05-31 15:39:57.002
Enabled for: Delayed Denali Exchange Data Feed. | 2022-05-31 15:39:57.002
Enabled for exchange2: CME | 2022-05-31 15:39:57.002
Enabled for exchange2: CBOT (Trading Account Required) | 2022-05-31 15:39:57.002
Enabled for exchange2: COMEX (Trading Account Required) | 2022-05-31 15:39:57.002
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-05-31 15:39:57.002
Enabled for exchange2: fairx_exchange.data | 2022-05-31 15:39:57.002
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-05-31 15:39:57.002
Current selected Data/Trading service: CQG WebAPI | 2022-05-31 15:39:57.002
Custom symbol settings values: enabled | 2022-05-31 15:39:57.002
Chart Update Interval: 500 | 2022-05-31 15:39:57.002
Intraday Data Storage Time Unit: 0 | 2022-05-31 15:39:57.002
Time Zone: +00:00:00 (UTC+00) | 2022-05-31 15:39:57.002
2022-05-31 15:39:57 Local computer time in UTC | 2022-05-31 15:39:57.002
2022-05-31 15:39:57 Local computer time in SC Time Zone | 2022-05-31 15:39:57.002
2022-05-31 11:39:24 Server time in UTC | 2022-05-31 15:39:57.002
Local computer UTC time and Server UTC time difference: 43 seconds. | 2022-05-31 15:39:57.002
Notice: Your computer's clock is off by 43 seconds. For help with this, press the 'Send for Analysis' button. | 2022-05-31 15:39:57.002
Program path: C:\SC\ | 2022-05-31 15:39:57.002
Data Files path: C:\SC\Data\ | 2022-05-31 15:39:57.002
OS Version Number: 10.0 | 2022-05-31 15:39:57.002
Locale Setting: C | 2022-05-31 15:39:57.002
DLLs: UserContributedStudies_64.dll | 2022-05-31 15:39:57.004
Allowed protected custom studies: | 2022-05-31 15:39:57.004
Crash reporter started: true | 2022-05-31 15:39:57.004
Socket (5) | CloseSocket call. | 2022-05-31 15:40:00.363
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-05-31 15:40:00.363
Historical data download thread signaled to stop. | 2022-05-31 15:40:00.363
HD Request # 76 | Timestamp of first Intraday data file record written: 2022-05-31 11:23:02.992000. | 2022-05-31 15:40:00.364
HD Request # 76 | Received 28464 Intraday data records from 2022-05-31 11:22:52.204000 to 2022-05-31 15:40:28.283003 (4.3 hours) and wrote 28463 records for F.US.JY6M22 | 2022-05-31 15:40:00.364
HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2022-05-31 15:40:28.283003 | 2022-05-31 15:40:00.371
HD Request # 76 | Completion time: 9s. | 2022-05-31 15:40:00.371
HD Request # 76 | Intraday data download complete for F.US.JY6M22. Unique request ID: 116 | 2022-05-31 15:40:00.371
Removing historical data download ID 116. | 2022-05-31 15:40:00.371
Real-time Intraday chart data file updates started for F.US.JY6M22 | 2022-05-31 15:40:00.371
Intraday chart data file opened for F.US.JY6M22 | 2022-05-31 15:40:00.371
HD Request # 76 | Enabling Intraday chart updating for symbol. | 2022-05-31 15:40:00.371
Triggering next historical data download in queue. | 2022-05-31 15:40:00.371
HD Request # 77 | Downloading Intraday chart data for F.US.CLEN22 to the file F.US.CLEN22.scid. Service: nymex | 2022-05-31 15:40:00.371
HD Request # 77 | Download start date-time: 2022-05-31 11:22:50.000000. File last date-time: 2022-05-31 11:22:50.825000 | 2022-05-31 15:40:00.372
HD Request # 77 | Using server: ds23.sierracharts.com port 80 | 2022-05-31 15:40:00.372
Socket (4) | Creating socket. | 2022-05-31 15:40:00.372
Socket (4) | New receive buffer size: 5242880 | 2022-05-31 15:40:00.372
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-05-31 15:40:00.372
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:00.455 *
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:00.475 *
Socket (5) | Socket gracefully closed by remote side. | 2022-05-31 15:40:00.549
Socket (5) | Closed. | 2022-05-31 15:40:00.550
HD Request # 77 | Setting DTC encoding to Binary VLS | 2022-05-31 15:40:00.835
HD Request # 77 | Sending historical data logon request message. | 2022-05-31 15:40:00.835
HD Request # 77 | Requesting Intraday data. Start date-time: 2022-05-31 11:22:50. Record interval: 0. Symbol: CLN22 | 2022-05-31 15:40:01.051
HD Request # 77 | Decompressing data. | 2022-05-31 15:40:02.018
HD Request # 77 | Receiving Intraday data for F.US.CLEN22 starting at 2022-05-31 11:22:50.714000 | 2022-05-31 15:40:02.018
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=17, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-43.9 seconds, DataCompRatio=1.33, UncompressedBytes=6904, CompressionTime=0.000529(secs), NumCompressions=118, Source=192.81.56.146 | 2022-05-31 15:40:05.583
DTC Client socket (2) | Connect event error. Windows error code 10060: 由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败。 | 2022-05-31 15:40:10.495 *
DTC Client socket (2) | CloseSocket call. | 2022-05-31 15:40:10.496
DTC Client socket (2) | Closed. | 2022-05-31 15:40:10.496
DTC Client socket (0) | CloseSocket call. | 2022-05-31 15:40:10.496
SC Data - All Services | Disconnected from the server. | 2022-05-31 15:40:10.496
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-05-31 15:40:10.496
SC Data - All Services | Connecting to the server 10.1.49.101. Port 443 | 2022-05-31 15:40:12.498
DTC Client socket (2) | Creating socket. | 2022-05-31 15:40:12.498
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-05-31 15:40:12.498
DTC Client socket (2) | Connecting to IP: 10.1.49.101. | 2022-05-31 15:40:12.498
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=8, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-44.1 seconds, DataCompRatio=1.47, UncompressedBytes=1035, CompressionTime=0.000181(secs), NumCompressions=11, Source=10.1.49.102 | 2022-05-31 15:40:15.301
HD Request # 77 | Timestamp of first Intraday data file record written: 2022-05-31 11:22:54.269000. | 2022-05-31 15:40:25.474
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=16, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-43.9 seconds, DataCompRatio=1.36, UncompressedBytes=9142, CompressionTime=0.000685(secs), NumCompressions=153, Source=192.81.56.146 | 2022-05-31 15:40:25.580
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:25.990 *
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:26.024 *
Socket (4) | CloseSocket call. | 2022-05-31 15:40:31.073
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-05-31 15:40:31.073
Historical data download thread signaled to stop. | 2022-05-31 15:40:31.073
HD Request # 77 | Received 86185 Intraday data records from 2022-05-31 11:22:50.714000 to 2022-05-31 15:40:43.583000 (4.3 hours) and wrote 86181 records for F.US.CLEN22 | 2022-05-31 15:40:31.074
HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2022-05-31 15:40:43.583000 | 2022-05-31 15:40:31.080
HD Request # 77 | Completion time: 31s. | 2022-05-31 15:40:31.080
HD Request # 77 | Intraday data download complete for F.US.CLEN22. Unique request ID: 117 | 2022-05-31 15:40:31.080
Removing historical data download ID 117. | 2022-05-31 15:40:31.080
Real-time Intraday chart data file updates started for F.US.CLEN22 | 2022-05-31 15:40:31.080
Intraday chart data file opened for F.US.CLEN22 | 2022-05-31 15:40:31.080
HD Request # 77 | Enabling Intraday chart updating for symbol. | 2022-05-31 15:40:31.080
Triggering next historical data download in queue. | 2022-05-31 15:40:31.080
HD Request # 78 | Downloading Intraday chart data for F.US.CPEN22 to the file F.US.CPEN22.scid. Service: comex | 2022-05-31 15:40:31.081
HD Request # 78 | Download start date-time: 2022-05-31 11:22:35.000000. File last date-time: 2022-05-31 11:22:35.094000 | 2022-05-31 15:40:31.081
HD Request # 78 | Using server: ds21.sierracharts.com port 80 | 2022-05-31 15:40:31.081
Socket (5) | Creating socket. | 2022-05-31 15:40:31.081
Socket (5) | New receive buffer size: 5242880 | 2022-05-31 15:40:31.081
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-05-31 15:40:31.081
Socket (4) | Socket gracefully closed by remote side. | 2022-05-31 15:40:31.290
Socket (4) | Closed. | 2022-05-31 15:40:31.290
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:31.469 *
Error creating/opening the file for exporting bar data. Error: Windows error code 3: 系统找不到指定的路径。 | 2022-05-31 15:40:31.485 *
DTC Client socket (2) | Connect event error. Windows error code 10060: 由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败。 | 2022-05-31 15:40:33.550 *
DTC Client socket (2) | CloseSocket call. | 2022-05-31 15:40:33.550
DTC Client socket (0) | CloseSocket call. | 2022-05-31 15:40:33.550
SC Data - All Services | Disconnected from the server. | 2022-05-31 15:40:33.550
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-05-31 15:40:33.550
DTC Client socket (2) | Closed. | 2022-05-31 15:40:33.551
HD Request # 78 | Setting DTC encoding to Binary VLS | 2022-05-31 15:40:34.512
HD Request # 78 | Sending historical data logon request message. | 2022-05-31 15:40:34.512
HD Request # 78 | Requesting Intraday data. Start date-time: 2022-05-31 11:22:35. Record interval: 0. Symbol: HGN22 | 2022-05-31 15:40:35.179
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=8, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-44.1 seconds, DataCompRatio=1.43, UncompressedBytes=1097, CompressionTime=0.000192(secs), NumCompressions=12, Source=10.1.49.102 | 2022-05-31 15:40:35.304
HD Request # 78 | Decompressing data. | 2022-05-31 15:40:35.381
SC Data - All Services | Connecting to the server 10.1.49.101. Port 443 | 2022-05-31 15:40:35.551
DTC Client socket (2) | Creating socket. | 2022-05-31 15:40:35.551
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-05-31 15:40:35.551
DTC Client socket (2) | Connecting to IP: 10.1.49.101. | 2022-05-31 15:40:35.551
[2022-05-31 21:33:41]
We are not seeing anything regarding chartbooks in your log, but we do see the following:
The first and second lines are stating that there is an issue saving data to a file. Make sure you have proper permissions to write to that file and that the drive is not full.
The last entry is stating that you are having a network error. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
