Date/Time: Tue, 04 Nov 2025 11:33:55 +0000
Numbers Bars - Background Type Ask/Bid Diagonal Dominant Volume Split Profile
View Count: 1070
|   [2022-05-14 11:34:44]     |
| User120942 - Posts: 75 |
                @Sierra Chart Engineering I would like to request a new Column Background Type that draws the background profile displaying only the profile of the diagonal dominant delta value at each price level. The length of each profile would auto adjust based on the maximum dominant -/+ delta value of the entire profile. Currently this is not available for the Sierra Chart Numbers Bars to visually compare the diagonal delta in each Numbers Bars. 1. This background type would only draw a delta profile on the dominant diagonal delta side of the Ask/Bid column. If the diagonal delta is positive a profile would be drawn on the right side of the profile only. If the diagonal delta is negative a profile would be drawn on the left side of the profile only. 2. The length of each profile would be relative to the maximum profile value -/+ in the profile. There would always be one profile that is 100% of the maximum length of the bar on either side of the Ask/Bid split profile. For Example If the maximum delta of the bar is a negative delta value of -500 then the left side delta would be the maximum delta width and the other values in the bar would be relative to that maximum delta value. If the maximum delta of the bar is a positive delta value of +500 then the right side delta would be the maximum delta width and the other values in teh bar would be relative to that maximum delta value. It is possible with this background type to have a profile on either side of a single price level if the -/+ delta values are high at the bid and the ask. The intent of this background type is to easily see which side of the bar is the dominant side without having to look at the text at each price level. Currently, the split background types currently available colors both sides of the diagonal delta the same color. Please see the attached screenshot as an example. Thank You Date Time Of Last Edit: 2022-05-14 11:37:33
|   [2022-05-16 15:49:34]     |
| John - SC Support - Posts: 42737 |
                We have set this as a Feature Request.
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2022-05-17 04:48:34]     |
                Hi @John - SC Support, Thanks for your consideration. Looking forward to that future update. Much appreciated.  |
|   [2023-08-31 06:19:32]     |
| Anders Dybdahl - Posts: 19 |
                Hi! Any news on this functionality? I would really like to see this implemented, but also with an "at price" option, not just diagonally. Thanks! Best regards Anders, Sweden  |
