Date/Time: Wed, 12 Mar 2025 11:49:14 +0000
Sierra freezes when using volume profiles
View Count: 564
[2022-05-12 20:25:41]
Mustang77 - Posts: 122
Hi
its impossible to set up a ES chart with daily volume profiles, i start chart, add the study and configure it, then if i scroll back to few months back the platfrom freezes and crashes, and i can't even close it, i have to go to task manager on Windows to shut it down.
I have the latest version 2393 and a powerful PC.
What can be the problem ?
[2022-05-12 21:17:43]
John - SC Support - Posts: 38598
We wonder if you might have some bad data from CQG from a few months back. To ensure that all the data is from our Denali Exchange Data Feed, please have the chart that is giving you issues active, then select Edit >> Delete All Data and Download. If you are given a selection of contracts to choose from to redownload, be sure you Select All.
After the data redownloads and populates, see if you continue to have an issue.
[2022-05-13 05:32:46]
Refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing
Also increase this Volume by Price Input setting:
Volume By Price Study: Ticks Per Volume Bar
[2022-05-15 10:43:13]
Hi
Thanks for your reply.
I checked all that.
The purpose of me trying to use the volume profile, is to see where the POC's are from previous volume profiles, up to 3 years ago for example.
So if i set the volume profile to "multiple profiles set on fixed time" and set the fixed time to 1 day, or 1 week, or 1 month, the problem is it does not let me scroll back more than 1 year.
The other struggle i'm finding is hot to actually scroll back? if i drag the bottom scale right and left it doesn't work properly.
How can i have it set as close as possible to TradingView style? in other works scroll with the mouse wheel while having the chart values tool on ?
I really like Sierra but at the moment i am wasting a lot of time to simply have a chart with volume profiles on it.
Waiting to hear from you, perhaps you could tell me the best settings for what i'm trying to achieve, i mean the ticker is ES and almost everyone trades that.
[2022-05-15 12:43:40]
We want you to increase the Chart >> Chart Settings >> Tick Size by 100 or 1000 times and see if you still have a problem:
This will help diagnose the problem.
Add the scrollbar back to the chart and do not remove the scrollbar:
We should not be asked how to scroll a chart back if the scrollbar has been removed. Refer to:
Chart Menu: Show Scrollbar (Chart menu)
Finally, if the issue is you want to load more data in the chart, then refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
Date Time Of Last Edit: 2022-05-15 19:35:42
