Date/Time: Wed, 12 Mar 2025 06:00:40 +0000
Order modification notification default
View Count: 516
[2022-05-05 20:23:03]
DCSaba - Posts: 113
Whenever I chose a new Order Bracket type in the Trade Window, I always have to uncheck the tick beside the Notification setting for "Confirm Order Modification". Is there a way to set this to be unticked by default?
[2022-05-05 20:42:32]
John - SC Support - Posts: 38598
It may be "unticked" by default to start with, but if you are selecting a saved Trade Configuration file to change your order bracket type, then the status of the confirmations is getting changed with that configuration. In other words, the confirmation options are saved with the configuration file. Therefore, you would want to deselect the confirmations you do not want and then resave your configuration file.
Refer to the following regarding the order configurations:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
[2022-05-06 11:38:00]
DCSaba - Posts: 113
Thank you Sirs,
I would have totally missed this nuance.
Indeed, I just had to save the bracket AFTER I changed the Confirmation Setting to None and indeed it remembers it now!
Thank you and all the best,
[2022-05-06 11:40:43]
DCSaba - Posts: 113
If you'd allow another question:
Is there a way to automate the "BE" (move Stop to Break Even), to trigger automatically once the 1 Set Target has been reached?
[2022-05-06 11:44:58]
Yes. Refer to this functionality:
Attached Orders: Move to Breakeven for Stop
[2022-05-06 18:37:30]
DCSaba - Posts: 113
Pertaining to this question: The Order Fills: Is it possible to not only change the colors of those triangles, but also their shape and size?
[2022-05-06 20:15:16]
You can change the size, but not the shape. Refer to the following:
Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
