Date/Time: Tue, 11 Mar 2025 17:33:45 +0000
How do I get the keyboard short cut descriptions to show up in the menu
View Count: 510
[2022-05-02 14:21:17] |
User967921 - Posts: 7 |
How do I get the keyboard short cut descriptions to show up in the menu options like in the picture?
![]() Attachment Deleted. |
[2022-05-02 17:25:58] |
John - SC Support - Posts: 38580 |
As long as they are set, then they will show in there. It looks like you may have cleared all the keyboard shortcuts by selecting the button for Clear All Shortcuts on the Global Settings >> Customize Keyboard Shortcuts window. If this is the case, then you can reset them to the defaults by selecting the button for Set All to Defaults on the same window. Just keep in mind that any customized keyboard settings will be removed when you select this option. Refer to the information for customizing Keyboard Shortcuts here: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
