Date/Time: Tue, 11 Mar 2025 18:07:25 +0000
Sierra Chart Second Instance Data Files Folder Keeps Resetting
View Count: 512
[2022-04-30 17:23:19]
PepeTrader - Posts: 12
In my 2nd instance of Sierra Chart, I set the path to my original instance of Sierra Chart:
General Settings -> Paths
- Data Files Folder (Action): F:\SierraChart\Data
- Always Use 'Data' Folder Within Main Folder: No
This works great. I can open my charts, and they don't need to re-download their data again, etc.
But once I restart the 2nd instance, it's back to:
- Data Files Folder (Action): F:\SierraChart\SierraChartInstance_2\Data
- Always Use 'Data' Folder Within Main Folder: Yes
Is there a way to make this so I don't have to manually change it every time I reload the 2nd instance?
Thanks!
Date Time Of Last Edit: 2022-04-30 17:24:26
[2022-05-01 07:35:09]
You absolutely cannot do what you are describing here. This is going to cause you corruption issues and problems . You already probably have a corruption issue:
All of your chart data files at this point should be considered corrupt. And you need to re-download the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Date Time Of Last Edit: 2022-05-01 07:35:56
