Date/Time: Tue, 04 Nov 2025 18:08:28 +0000
Gene Sheldon
View Count: 1464
| [2014-04-25 21:08:36] |
| User72965 - Posts: 116 |
http://www.sierrachart.com/image.php?l=139845992910.png I see another Trade DOM Graph Need OverLays?? I used just Upload Chart here. Thx Gene ;) |
| [2014-04-25 21:30:02] |
When you respond, do not start a new Support Request but instead post within the very same thread in the Message box at the bottom of the page. We think the problem might have something to do with the color settings. Here is the documentation for that: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-01 21:16:11
| [2014-05-01 16:42:41] |
Still no DOM Graph Numbers or % Don't get anything in Mkt. Depth window either . Don't know if any connection ?? Read colors ~~ did not get anything there ??? I might not understand what to look for . http://www.sierrachart.com/image.php?l=1398962469926.png Do any good to send Log ???? Sure like to get DOM Graph > Had it on 1097 version ~~ Thx Gene :) |
| [2014-05-01 17:15:22] |
I can't enable the Dom Graph from chart settings ??? I get only lines >> From Show ask bid lines in chart settings. On left side 1/2 way down. Can't do anything from Advance #2 ??? Tried unlock fill <> no help ??? Thx Gene |
| [2014-05-01 21:53:49] |
Have you considered using the Sierra Chart Real-time and Historical Exchange Data Feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php instead of IQ Feed. Based upon your most recent postings, this sounds like there is a problem receiving depth data from IQ Feed. Maybe you are not subscribed to it. You can get market depth for a much lower cost with the Sierra Chart Data Feed. There is no further help we can provide. You will need to contact IQ Feed or use the Sierra Chart Data Feed. We assume you have a futures trading account? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-01 21:54:30
| [2014-05-30 16:35:36] |
No DOM Graph on 1137 version either . Note My Friend has DTN IQ 5.0.0.14 Mine is 5.1.0.4 DTN says same ??? He has Sierra DOM Graph on Sierra . I do not ??? Puzzling ??? Am wondering what I need in Sierra Data Feed to Get Historical feed And DOM Graph ?? Not interested in Trading off Sierra charts at the moment . Hoping you can send pkg. identification that I need . Thx : Gene Any trial periods on trying Sierra feed. Says something about that On support page . I follow The ES Mimi Russel & Euro .. |
| [2014-05-30 16:54:11] |
Follow the set up instructions here to use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php To get market depth for CME futures you need to activate the CME Group exchange with market depth. It is 15.75 USD per month. Did you need real-time data for the Russell? If so, you need to pay the ICE US exchange fee.? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
