Date/Time: Thu, 16 Jul 2026 06:54:46 +0000
Live EUREX data ?
View Count: 834
[2022-04-28 07:00:38]
User877753 - Posts: 152
No EUREX data at all this morning ?
Does anyone else encounter the same issue ?
US markets working fine.
[2022-04-28 07:05:33]
I get this : see picture attached
image2022-04-28 09_02_33.png / V - Attached On 2022-04-28 07:04:56 UTC - Size: 3.57 KB - 227 views
[2022-04-28 10:56:01]
We apologize for this. Restart Sierra Chart. Enable the "Force Login" option on the login window. We are not sure why this circumstance occurs. We are going to look into this again today.
Date Time Of Last Edit: 2022-04-28 10:56:05
[2022-04-28 11:04:41]
We discovered the reason for the problem and we are implementing a solution to it now. This will require an update which we will put out today.
The basic problem is that the server address was not being permanently saved in the configuration file of Sierra Chart and if there was a login failure to the Sierra Chart server upon startup, there would be no server address and the default one would be used instead.
Date Time Of Last Edit: 2022-04-28 11:37:58
