Date/Time: Tue, 11 Mar 2025 01:26:15 +0000
HOW DO I CONNECT PACKAGE 12
View Count: 508
[2022-04-21 18:38:20] |
User495556 - Posts: 1 |
TURN ON PACKAGE 12
[2022-04-21 20:23:57] |
John - SC Support - Posts: 38547 |
We see your account is already on Package 12. The first thing you need in order to get the Market by Order data is the data from the Denali Exchange Data Feed. You can not see Market by Order data from any other data feed in Sierra Chart. When you activate the exchanges you want, make sure you get the Market Depth data, as this is required to get the MBO information. Refer to the instructions for the CME Group here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you want data for EUREX, CFE, or NASDAQ TotalView, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Once you have the data feed setup, you will need to go through the instructions at the following link to finish the setup for the MBO data: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
