Date/Time: Tue, 11 Mar 2025 00:59:08 +0000
Depth of Market
View Count: 457
[2022-04-21 15:12:46]
Marlin46 - Posts: 34
Many times on the Trading DOM/Ladder I am getting into trades in SIM before the price actually hits my entry, does the DOM have an incremental setting that puts an order into a trade based on smaller increments? I have noticed that my entry sometimes will sit between prices on the trading DOM/ladder once I am in a trade. Hope you can understand my question. Thanks so much.
[2022-04-21 15:34:28]
John - SC Support - Posts: 38547
The DOM may not be showing all of the price increments. It shows the prices that can fit on the screen and be read easily. Also, when in Automatic mode (the default) it is trying to fit the bars onto the screen. You can always adjust up or down as needed/wanted. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scaling
You can check the price increment that the instrument trades in by looking at the Chart >> Chart Settings >> Symbol >> Tick Size. Refer to the following:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
