Date/Time: Mon, 10 Mar 2025 17:31:47 +0000
Change in Laptops
View Count: 525
[2022-04-06 16:54:31]
User822226 - Posts: 1
Good day,
I have changed my old model laptop to a new one, and unfortunately i seem to have lost all my saved data. I initially saved a lot of order flow or footprint charts
but now i cannot find it when loggin in with the same credentials.
How do i retrieve my saved data?
Sierra chart seem to have been greyed out as well in this new laptop.
[2022-04-06 17:23:09]
John - SC Support - Posts: 38542
All your Sierra Chart information is saved locally. Therefore it is on the old laptop within the Sierra Chart folder on that system. You would need to copy it to the new system. Refer to the information here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
We do not know what you mean by "Sierra chart seem to have been greyed out as well in this new laptop." Can you give us more information, as it sounds like you were able to run the software.
