Date/Time: Mon, 10 Mar 2025 17:27:38 +0000
LOST DATA SETTING
View Count: 538
[2022-04-05 10:03:41] |
JIHANE SEHAD - Posts: 18 |
Hello, I have reset my computer yesterday and re install Sierra chart this morning, unfortunately all my settings are gone..Even the balance is at 0$ or I have something like 25$. Is there any chance for you to put all my settings back please? I hope so, otherwise it s a lot of time spend for nothing :( Thank you Jihane |
[2022-04-05 11:41:13] |
Did you have a backup of your Sierra Chart installation? That is not something that Sierra Chart would have on our servers. Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Even the balance is at 0$
Are you referring to your Sierra Chart Services Balance? That will not have changed in any way related to your local Sierra Chart installation on your computer.
