Date/Time: Mon, 10 Mar 2025 14:36:30 +0000
Strange circles on chart messing up the view
View Count: 497
[2022-03-28 19:03:59] |
User237768 - Posts: 5 |
Hi I have got several strange circles on my ES chart that seems to be placed a proce point 0 and at the start of the new RTH. This totally messesup the chart. Can anyone help here I do not seem to be able to get rid of them. https://www.sierrachart.com/image.php?Image=1648494277865.png Date Time Of Last Edit: 2022-03-28 19:04:57
[2022-03-28 19:24:11] |
John - SC Support - Posts: 38517 |
They are either drawings or something from a study. Therefore, start by opening Tools >> Manage Chart Drawings Window to see if they are drawings and remove them from that window. Otherwise, select Analysis >> Studies and see what studies you have on the chart. You can remove, or hide, them one by one until you find the culprit. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-29 06:34:22] |
Hi Thanks for your help. It was the TextLabels SubGraph below the ZigZag Study. |
