Date/Time: Fri, 11 Sep 2026 07:04:23 +0000
Some Tools disappear under Fill Rectangle Top SG
View Count: 830
| [2022-03-21 08:46:55] |
| PS2004 - Posts: 49 |
Hi! I have a Study which colors the background of the Chart at some ranges. I used the "Fill Rectangle Top" drawstyle for this. If I draw some type of Tools on that part of the Chart, either manually or through ACSIL, they tend to disappear. I experience this with Ellipse, Retracement, Triangle Tool types for example. If I use Tools which contain only one line (Line, Paralell Lines, Arrow), they work fine. What can cause this, and how can I get around this issue? Refer to the attached picture. |
| [2022-03-21 09:07:52] |
Refer to this section here regarding this: Chart Drawing Tools: Controlling Display Order of Chart Drawings Relative to Graphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
