Date/Time: Mon, 10 Mar 2025 06:50:27 +0000
why Disappears Sl at the time of opening the position?
View Count: 488
[2022-03-18 14:36:28] |
User716459 - Posts: 135 |
why Disappears Sl at the time of opening the position? Why does it only close some contracts, while the rest remain open?
[2022-03-18 15:17:00] |
Are you referring to a Stop Attached Order? Maybe the orders are getting rejected. You can see these rejections in the Trade Service Log: Trading Information Windows: Trade Service Log For order routing we definitely recommend using the Teton order routing service: Sierra Chart Teton Futures Order Routing This may solve the issue, because it could be that CQG is rejecting the orders due to additional margin requirements. Whereas with Teton this would not happen. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-18 15:18:27
