Date/Time: Mon, 05 Oct 2026 10:50:14 +0000
study question
View Count: 905
[2022-03-11 14:53:52]
User427421 - Posts: 48
Is there a way to show the Bid ask ratio volume for the session ? I see a study but it's a moving average and I just want to see what the total is for the current session.
[2022-03-11 16:27:43]
John - SC Support - Posts: 48095
There is not a study that does this directly.
The easiest thing to do would be to create an Intraday Chart with a single bar for the entire session time, then create the ratio using your preferred studies (such as the Numbers Bars Calculated Values and the Study Subgraph Divide). You can then display that value on your other chart using the Text Display from Study for Chart.
[2022-03-11 16:36:32]
Sawtooth - Posts: 4355
You can also do it with 3 native studies:
1. Add the Cumulative Sum Of Study study.
- Check 'Hide Study'.
- Set 'Reset At Start Of Trading Day' to Yes.
- Set 'Study and Subgraph to Reference' to <Main Price Graph> and Bid Volume.
2. Duplicate the above Cumulative Sum Of Study study.
- Set 'Study and Subgraph to Reference' to <Main Price Graph> and Ask Volume.
3. Add the Study Subgraphs Divide/Ratio study.
- Set each Input Study to a Cumulative Sum Of Study.
(Swap them for the ratio you want.)
Date Time Of Last Edit: 2022-03-11 17:53:37
