Date/Time: Sat, 19 Apr 2025 15:21:54 +0000
Pull/Stack Combine Increment in Ticks
View Count: 2082
[2022-03-09 16:44:50] |
tdd2672 - Posts: 61 |
Would it be possible to add this capability to the Pull/Stack column? It works perfectly for Market Depth and would be great to be able to do the same with P/S.
[2022-03-09 16:57:16] |
I added an image. This is the NQ chart with Market Depth set to 3 ticks combined but Pull/Stack at a single tick. I try to keep 100 points visible at all times on the NQ which means that I'm compressing the MD and PS numbers. It would be good to have the numbers combined and easy to read.
Date Time Of Last Edit: 2022-03-09 17:04:50
[2022-03-09 18:01:06] |
John - SC Support - Posts: 39362 |
We have set this as a Feature Request. This has been requested several times, so it will get some attention when we can spend some time on it.
[2022-06-17 03:24:21] |
In addition to the Combine Increments it would be great to also include Number of Levels for Bid/Ask Depth Calculations and Maximum Pull/Stack levels, same as Market Depth.
[2022-10-28 17:50:03] |
Has there been any progress with this request?
[2022-10-28 20:41:02] |
We are almost done with the combining for the Recent and Current Bid/Ask columns. Once we have that released we will work on the Pulling/Stacking columns. But, as is our usual caveat, we can not say when we will be able to actually finish the work and release it.
[2023-04-23 14:09:02] |
FinalDevil - Posts: 10 |
Hi John, do you have any update on this?
[2023-04-24 15:12:41] |
Sorry, things have gotten busy with other items and we have not had time to work on this. It is one of the items we want to get to, but it is just hard to find the time.
[2023-06-26 00:41:13] |
User861257 - Posts: 12 |
Looking to +1 this request, this would pair perfectly with the equities data you just released.
[2023-09-14 15:39:24] |
Bump
[2024-02-20 16:56:41] |
Wernitschanton - Posts: 34 |
+1 Really important feature for anyone trading NQ =)
[2024-02-20 17:23:29] |
The ability to combine the "Recent Bid/Ask" columns has been released for the last few releases. Refer to the following: Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) We do not know when we will be able to get to the rest of the columns. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 05:46:19] |
sxmiali - Posts: 6 |
seems like compressing the DOM (4 ticks under symbol settings for tick size) for NQ compresses the pull stack data in replay only when will this be available for live data?
[2024-09-04 01:59:10] |
joshtrader - Posts: 506 |
This is great, thank you for adding it! One thing I noticed is that when enabling this feature, the foreground/background highlighting does not work as it does when the feature is disabled. Is this straightforward to address? |
Attachment Deleted. ![]() ![]() |
[2024-10-03 17:39:01] |
User551647 - Posts: 25 |
Hi everyone, this "Apply combine increment in ticks" works only for the recent bid/ask volume as it seems. Is it possible to make it work for the other options in the "Customize Trade DOM Columns" as well? I am mainly using the "Current Traded Ask and Bid and Total Volume" and the pulling and stacking column Thank you very much in advance. |
[2024-10-03 17:49:35] |
As the title of the setting states - "Apply Combine Increment in Ticks to Recent Bid/Ask Volume Columns", this option only works on the Recent Bid/Ask columns. It has not been expanded yet to include the other columns. We do not know when we will get to having the other columns do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-03 17:58:11] |
Makes sense. Would be great to have this expanded to the others especially the kind of resetable footprint with the current traded columns provides great value to me would be great to use it on NQ with the combined ticks. Thank you once more |
[2024-10-22 13:03:07] |
I still would love to see this implemented on the Pull/Stack columns.
[2025-03-05 23:13:44] |
d9e5c763 - Posts: 111 |
pull/stack columns also don't seem to work as expected when used as a dtc client I pre-combine the market depth data passed to the client by reading the custom data directly from file CustomSymbolSettings.dtc.xml, so my combine increment in ticks value is always set to 0 when I adjust the tick size of a symbol from large(0.0005) to small(0.0001, symbol default value), the pull/stack column does not calculate based on the new tick size, it still calculates based on the previous larger tick size(0.0005) unless I reconnect(screenshot 0.0005.jpg and 0.0001.jpg) when the tick size is not the symbol default, the numbers in the current traded total volume column are stacked together and not combined(screenshot CurrentTradedTotalVolume.jpg) |
[2025-03-10 22:28:27] |
the latest version (2746) mentions improvements to pulling and stacking columns, I upgraded to this version after the tick size is changed from small to large, the pulling and stacking columns will no longer overlapping numbers, and the current traded total volume has not changed when the tick size is changed from large to small, the pulling and stacking columns will still skip the calculation of multiple prices |
