Date/Time: Sun, 13 Sep 2026 14:51:26 +0000
Issue with Sierra Chart
View Count: 718
| [2022-03-08 15:12:36] |
| User201780 - Posts: 1 |
Hi, I discover Sierra chart 2 weeks ago and at that time I set up an account but unfortunately I was able to only test trial yesterday. During my testing yesterday I went to some issues: 1) I created BTCUSDT chart with volume data (Cumulative Delta Bars – Volume, Initial Balance, Volume By Price, Volume Value area Lines, Volume Weighted Average Price) and then when I duplicate the chart and wanted to add TPO profile chart your software stuck. After restarting the system I was able to add it as a new chart (not by duplicating the chart) but everything was so slow that I couldn't change the coloring etc. Both charts were in the same chartbook. 2) Further I tried to add chart with Numbers Bar but it completely didn't work. The chart was loading to 99.6% and nothing happen after. I changed the Use Number of Days to Load from 30 to 2 and it didn't help. I checked the system requirements and my laptop fulfill it. Unfortunately your software works so slow that make it impossible to use :/ is there any way to make it better? I was considering to use Service Package 3 or 5 but the trial version didn't meet my expectations. If there is any workaround to make the software work faster, would it be possible to extend my trial so I can test it further and make sure that all my studies are loading and work as intended? Thank you and looking forward to your reply. BR, Anna |
| [2022-03-08 17:23:48] |
| John - SC Support - Posts: 47854 |
We have reset your trial for your account as it appears you have not used any of your time.
| [2022-03-08 18:07:15] |
| Tony - Posts: 725 |
I am confidence that the slowness is caused by other issues, i.e. Operation System, Internet connection etc. I have tested all major charting software, Sierra is The fastest, and most efficient and powerful, other programs are not even close. I would try to isolate the issues, for example, instead load all the studies at once, try to load one at a time, or load 5 to 6 days on a chart instead of months, and then go from there. Good Luck! |
