Date/Time: Wed, 30 Sep 2026 03:13:03 +0000
Alert manager always goes to the top
View Count: 819
| [2022-03-08 12:24:05] |
| User361939 - Posts: 169 |
Hello, When there is a lot of alerts in alert manager, I am interested only to see the last one ( but i don't want to clear alert manager). Unfortunatelly when new alert hits alert manager, view goes to the Top (it should stay with last one). Attaching video to show the bug. Best Regards |
Private File |
| [2022-03-08 16:28:16] |
| John - SC Support - Posts: 48062 |
We recommend using the Pop-Up Alert instead of the Alert Manager. Refer to the following: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-08 17:21:57] |
Question is, should alert manager behaves like this? It makes no sense that it goes into top when the recent alert is on the bottom. Do you think, that you can change this? Ps. with numbers of alerts, having "Pop-Up Alert" would be very distracting for trader, cuz he needs to close all of those alerts. With alert manager he can choose on which he/she reacts. Date Time Of Last Edit: 2022-03-08 17:22:14
| [2022-03-08 18:52:15] |
We will look into the issue now. For now, select the very last line in the Alerts log to keep it scrolled to the bottom.
