Date/Time: Thu, 24 Sep 2026 09:43:29 +0000
Teton has been disconnecting many times
View Count: 872
[2022-03-03 17:15:16]
User976943 - Posts: 39
Yesterday I switched to Denali-Teton from TransAct. I have been testing everything today before I start trading live. But I have had the Issue that Sierra has disconected many times. Here is latest Message Log:
Software version: 2364 64-bit | 2022-03-03 10:02:55.034
Primary Thread ID: 13956 | 2022-03-03 10:02:55.034
Usage end date: 2022-03-14 | 2022-03-03 10:02:55.034
Enabled for: Sierra Chart Historical Data Service. | 2022-03-03 10:02:55.034
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-03-03 10:02:55.034
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-03 10:02:55.034
Enabled for exchange2: CME | 2022-03-03 10:02:55.034
Enabled for exchange2: fairx_exchange.data | 2022-03-03 10:02:55.034
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-03 10:02:55.034
Current selected Data/Trading service: Teton CME Order Routing | 2022-03-03 10:02:55.034
Custom symbol settings values: enabled | 2022-03-03 10:02:55.034
Chart Update Interval: 500 | 2022-03-03 10:02:55.034
Intraday Data Storage Time Unit: 0 | 2022-03-03 10:02:55.034
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-03-03 10:02:55.034
2022-03-03 16:02:55 Local computer time in UTC | 2022-03-03 10:02:55.034
2022-03-03 10:02:55 Local computer time in SC Time Zone | 2022-03-03 10:02:55.034
2022-03-03 15:37:27 Server time in UTC | 2022-03-03 10:02:55.034
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-03-03 10:02:55.034
Program path: C:\SierraChart\SierraChartTransActMA\ | 2022-03-03 10:02:55.034
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2022-03-03 10:02:55.034
OS Version Number: 10.0 | 2022-03-03 10:02:55.034
Locale Setting: C | 2022-03-03 10:02:55.034
DLLs: HindsightTrading.dll, HindsightTradingLevels.dll, kiwi10.dll, kiwi12.dll, kiwi8.dll, kiwi8a.dll, sst_vwap_bundle_64.dll, Top9Trader.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll | 2022-03-03 10:02:55.034
Allowed protected custom studies: | 2022-03-03 10:02:55.034
Saved Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht. Time: 0.0861 seconds. | 2022-03-03 10:03:40.527
DTC Client socket (1) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 10:06:37.454 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-03-03 10:06:37.454
DTC Client socket (1) | CloseSocket call. | 2022-03-03 10:06:37.455
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 10:06:37.455
Connection to the external service has been lost. | 2022-03-03 10:06:37.455
DTC Client socket (1) | Closed. | 2022-03-03 10:06:37.455
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-03-03 10:06:37.473
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:06:37.474
Teton CME Order Routing | Disconnected. | 2022-03-03 10:06:37.474
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:06:37.474
DTC Client socket (3) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 10:06:39.142 *
DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-03-03 10:06:39.142
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:06:39.143
DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 10:06:39.143
SC Data - All Services | Waiting for socket receive thread to end | 2022-03-03 10:06:39.143
DTC Client socket (3) | Closed. | 2022-03-03 10:06:39.143
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:06:39.144
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:06:39.144
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:06:39.144
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-03 10:06:39.470
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 10:06:39.619
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 10:06:39.619
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-03 10:06:39.619
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-03-03 10:06:41.151
DTC Client socket (3) | Creating socket. | 2022-03-03 10:06:41.165
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:06:41.165
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-03-03 10:06:41.165
DTC Client socket (2) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 10:06:41.817 *
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-03-03 10:06:41.817
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:06:41.817
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 10:06:41.817
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-03-03 10:06:41.817
DTC Client socket (2) | Closed. | 2022-03-03 10:06:41.817
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:06:41.818
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:06:41.818
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:06:41.818
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-03-03 10:06:43.822
DTC Client socket (2) | Creating socket. | 2022-03-03 10:06:43.822
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 10:06:43.822
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-03 10:06:43.822
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:00.646 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 10:07:00.646
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 10:07:00.646
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:00.646
DTC Client socket (1) | Closed. | 2022-03-03 10:07:00.646
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:00.661
Teton CME Order Routing | Disconnected. | 2022-03-03 10:07:00.661
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:00.661
DTC Client socket (3) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:02.199 *
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:07:02.199
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:02.199
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:07:02.199
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:02.199
DTC Client socket (3) | Closed. | 2022-03-03 10:07:02.199
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-03 10:07:02.663
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 10:07:02.664
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 10:07:02.664
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-03 10:07:02.664
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-03-03 10:07:04.189
DTC Client socket (3) | Creating socket. | 2022-03-03 10:07:04.190
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:07:04.190
DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-03-03 10:07:04.190
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:04.840 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:07:04.840
DTC Client socket (2) | Closed. | 2022-03-03 10:07:04.840
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:04.840
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:07:04.840
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:04.840
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-03-03 10:07:06.828
DTC Client socket (2) | Creating socket. | 2022-03-03 10:07:06.829
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 10:07:06.829
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:07:06.829
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:23.697 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 10:07:23.698
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 10:07:23.698
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:23.698
DTC Client socket (1) | Closed. | 2022-03-03 10:07:23.698
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:23.768
Teton CME Order Routing | Disconnected. | 2022-03-03 10:07:23.768
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:23.768
DTC Client socket (3) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:25.221 *
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:07:25.225
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:25.225
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:07:25.225
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:25.225
DTC Client socket (3) | Closed. | 2022-03-03 10:07:25.225
Teton CME Order Routing | Connecting to the server futurestrading1.sierracharts.com. Port 11093 | 2022-03-03 10:07:25.762
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 10:07:25.838
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 10:07:25.838
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:07:25.838
SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 10048 | 2022-03-03 10:07:27.237
DTC Client socket (3) | Creating socket. | 2022-03-03 10:07:27.237
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:07:27.237
DTC Client socket (3) | Connecting to IP: 64.38.174.178. | 2022-03-03 10:07:27.238
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:27.847 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:07:27.847
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:27.847
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:07:27.847
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:27.847
DTC Client socket (2) | Closed. | 2022-03-03 10:07:27.850
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-03-03 10:07:29.845
DTC Client socket (2) | Creating socket. | 2022-03-03 10:07:29.845
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 10:07:29.845
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2022-03-03 10:07:29.846
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:46.860 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 10:07:46.860
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 10:07:46.861
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:46.861
DTC Client socket (1) | Closed. | 2022-03-03 10:07:46.861
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:46.876
Teton CME Order Routing | Disconnected. | 2022-03-03 10:07:46.876
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:07:46.876
DTC Client socket (3) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:48.249 *
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:07:48.261
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:48.261
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:07:48.261
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:48.261
DTC Client socket (3) | Closed. | 2022-03-03 10:07:48.261
Teton CME Order Routing | Connecting to the server futurestrading1.sierracharts.com. Port 11092 | 2022-03-03 10:07:48.873
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 10:07:48.874
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 10:07:48.874
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:07:48.874
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-03-03 10:07:50.251
DTC Client socket (3) | Creating socket. | 2022-03-03 10:07:50.252
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:07:50.252
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:07:50.252
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:07:50.867 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:07:50.867
DTC Client socket (2) | Closed. | 2022-03-03 10:07:50.867
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:07:50.867
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:07:50.867
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:07:50.867
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2022-03-03 10:07:52.856
DTC Client socket (2) | Creating socket. | 2022-03-03 10:07:52.857
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 10:07:52.857
DTC Client socket (2) | Connecting to IP: 64.38.174.178. | 2022-03-03 10:07:52.857
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:08:09.897 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 10:08:09.897
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 10:08:09.897
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:08:09.897
DTC Client socket (1) | Closed. | 2022-03-03 10:08:09.897
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:08:09.912
Teton CME Order Routing | Disconnected. | 2022-03-03 10:08:09.913
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 10:08:09.913
DTC Client socket (3) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:08:11.278 *
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:08:11.294
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:08:11.294
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:08:11.294
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:08:11.294
DTC Client socket (3) | Closed. | 2022-03-03 10:08:11.294
Teton CME Order Routing | Connecting to the server futurestrading7.sierracharts.com. Port 11092 | 2022-03-03 10:08:11.903
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 10:08:12.046
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 10:08:12.046
DTC Client socket (1) | Connecting to IP: 38.89.235.129. | 2022-03-03 10:08:12.046
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-03-03 10:08:13.324
DTC Client socket (3) | Creating socket. | 2022-03-03 10:08:13.324
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:08:13.324
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-03-03 10:08:13.324
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 10:08:13.878 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:08:13.881
DTC Client socket (0) | CloseSocket call. | 2022-03-03 10:08:13.881
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:08:13.881
DTC Client socket (2) | Closed. | 2022-03-03 10:08:13.882
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 10:08:13.882
Teton CME Order Routing | Network connection to server complete. | 2022-03-03 10:08:15.175
Teton CME Order Routing | Starting socket receive thread. | 2022-03-03 10:08:15.175
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-03-03 10:08:15.175
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-03-03 10:08:15.858
Teton CME Order Routing | Sending logon request message. | 2022-03-03 10:08:15.858
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-03-03 10:08:15.885
DTC Client socket (2) | Creating socket. | 2022-03-03 10:08:15.885
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 10:08:15.885
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-03 10:08:15.885
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-03-03 10:08:16.047
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-03-03 10:08:16.047
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 10:08:16.047
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-03-03 10:08:16.266
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-03-03 10:08:16.266
Teton CME Order Routing | Received logon response. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Server Name: SC DTC Server. Build=41200. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 10:08:16.450
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Trading is supported. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Order cancel and replace is supported. | 2022-03-03 10:08:16.450
Teton CME Order Routing | OCO Orders supported. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Bracket Orders supported. | 2022-03-03 10:08:16.450
Teton CME Order Routing | Connected to server complete. | 2022-03-03 10:08:16.450
DTC Client socket (3) | CloseSocket call. | 2022-03-03 10:08:16.451
SC Data - All Services | Disconnected from the server. | 2022-03-03 10:08:16.451
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-03-03 10:08:16.451
DTC Client socket (3) | Closed. | 2022-03-03 10:08:16.451
DTC Client socket (2) | CloseSocket call. | 2022-03-03 10:08:16.451
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 10:08:16.451
DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-03 10:08:16.451
Triggering next historical data download in queue. | 2022-03-03 10:08:16.452
Triggering next historical data download in queue. | 2022-03-03 10:08:16.453
Updated verified funded futures trading account ending date to: 2022-04-02 16:08:16 | 2022-03-03 10:08:16.453
No download requests in the queue to start downloads for. | 2022-03-03 10:08:16.466
DTC Client socket (2) | Write has completed. Shutdown being performed. | 2022-03-03 10:08:16.476
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-03 10:08:16.476
Mapping MESH22_FUT_CME to MESH22. Service code: cme | 2022-03-03 10:08:16.478
Using symbol data fast lookup vector | 2022-03-03 10:08:16.478
SC Data - All Services | Starting real-time market data updates for: MESH22_FUT_CME (MESH22). ID: 1 Service code: cme | 2022-03-03 10:08:16.478
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-03-03 10:08:16.478
SC Data - All Services | Requesting security definition data for: MESH22_FUT_CME (MESH22). ID: 1 | 2022-03-03 10:08:16.478
Added historical Intraday data request for MESH22_FUT_CME to the queue. | 2022-03-03 10:08:16.478
Intraday data recording state for symbol MESH22_FUT_CME is set to download 'Pending'. | 2022-03-03 10:08:16.478
Triggering next historical data download in queue. | 2022-03-03 10:08:16.478
DTC Client socket (3) | Creating socket. | 2022-03-03 10:08:16.479
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 10:08:16.479
DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-03-03 10:08:16.479
Delaying start of download for MESH22_FUT_CME | 2022-03-03 10:08:16.480
Mapping ESH22_FUT_CME to ESH22. Service code: cme | 2022-03-03 10:08:16.548
SC Data - All Services | Starting real-time market data updates for: ESH22_FUT_CME (ESH22). ID: 2 Service code: cme | 2022-03-03 10:08:16.548
SC Data - All Services | Requesting security definition data for: ESH22_FUT_CME (ESH22). ID: 2 | 2022-03-03 10:08:16.548
Mapping MCLJ22_FUT_CME to MCLJ22. Service code: nymex | 2022-03-03 10:08:16.548
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MCLJ22_FUT_CME (MCLJ22). ID: 3 Service code: nymex | 2022-03-03 10:08:16.548
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-03-03 10:08:16.548
SC DTC Delayed Exchange Data | Requesting security definition data for: MCLJ22_FUT_CME (MCLJ22). ID: 3 | 2022-03-03 10:08:16.548
DTC Client socket (4) | Creating socket. | 2022-03-03 10:08:16.548
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-03-03 10:08:16.548
DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:08:16.548
Updated verified funded futures trading account ending date to: 2022-04-02 16:08:16 | 2022-03-03 10:08:16.589
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH22_FUT_CME | 2022-03-03 10:08:16.607
Teton CME Order Routing | Received security definition for symbol MESH22_FUT_CME | 2022-03-03 10:08:16.607
SC Data - All Services | Network connection to server complete. | 2022-03-03 10:08:16.639
SC Data - All Services | Starting socket receive thread. | 2022-03-03 10:08:16.639
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 10:08:16.639
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22_FUT_CME | 2022-03-03 10:08:16.670
Teton CME Order Routing | Received security definition for symbol ESH22_FUT_CME | 2022-03-03 10:08:16.670
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-03-03 10:08:16.706
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-03-03 10:08:16.706
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 10:08:16.706
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-03-03 10:08:16.827
SC Data - All Services | Sending logon request message. | 2022-03-03 10:08:16.827
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-03-03 10:08:16.948
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-03-03 10:08:16.948
SC DTC Delayed Exchange Data | Received logon response. | 2022-03-03 10:08:17.647
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-03-03 10:08:17.647
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 10:08:17.647
SC DTC Delayed Exchange Data | Successfully connected. | 2022-03-03 10:08:17.647
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-03-03 10:08:17.647
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MCLJ22_FUT_CME -> MCLJ22 | 2022-03-03 10:08:17.647
SC Data - All Services | Received logon response. | 2022-03-03 10:08:17.736
SC Data - All Services | Server Name: SC Realtime Server. | 2022-03-03 10:08:17.736
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 10:08:17.736
SC Data - All Services | Successfully connected. | 2022-03-03 10:08:17.736
SC Data - All Services | Trading is not supported. | 2022-03-03 10:08:17.736
SC Data - All Services | Restarting real-time data updates for symbol: ESH22_FUT_CME -> ESH22 | 2022-03-03 10:08:17.736
SC Data - All Services | Restarting real-time data updates for symbol: MESH22_FUT_CME -> MESH22 | 2022-03-03 10:08:17.736
SC DTC Delayed Exchange Data | Received security definition for symbol MCLJ22_FUT_CME | 2022-03-03 10:08:17.865
SC Data - All Services | Received security definition for symbol ESH22_FUT_CME | 2022-03-03 10:08:17.954
SC Data - All Services | Received security definition for symbol MESH22_FUT_CME | 2022-03-03 10:08:17.954
Requesting market depth updates for: MESH22_FUT_CME if supported. | 2022-03-03 10:08:21.450
SC Data - All Services | Market Depth data has been rejected for symbol: MESH22_FUT_CME. Not authorized for market depth. | 2022-03-03 10:08:21.772
HD Request # 5 | Downloading Intraday chart data for MESH22_FUT_CME to the file MESH22_FUT_CME.scid. Service: cme | 2022-03-03 10:08:22.556
HD Request # 5 | Download start date-time: 2022-03-03 10:06:13.000000. File last date-time: 2022-03-03 10:06:13.180001 | 2022-03-03 10:08:22.556
HD Request # 5 | Using server: ds21.sierracharts.com port 10150 | 2022-03-03 10:08:22.557
Socket (5) | Creating socket. | 2022-03-03 10:08:22.557
Socket (5) | New receive buffer size: 5242880 | 2022-03-03 10:08:22.557
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-03-03 10:08:22.557
HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-03-03 10:08:22.881
HD Request # 5 | Sending historical data logon request message. | 2022-03-03 10:08:22.881
HD Request # 5 | Requesting Intraday data. Start date-time: 2022-03-03 10:06:13. Record interval: 0. Symbol: MESH22 | 2022-03-03 10:08:23.478
HD Request # 5 | Decompressing data. | 2022-03-03 10:08:23.644
HD Request # 5 | Receiving Intraday data for MESH22_FUT_CME starting at 2022-03-03 10:06:13.082000 | 2022-03-03 10:08:23.935
Socket (5) | CloseSocket call. | 2022-03-03 10:08:23.936
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-03-03 10:08:23.936
Historical data download thread signaled to stop. | 2022-03-03 10:08:23.936
HD Request # 5 | Timestamp of first Intraday data file record written: 2022-03-03 10:06:13.217000 | 2022-03-03 10:08:23.936
HD Request # 5 | Received 5536 Intraday data records from 2022-03-03 10:06:13.082000 to 2022-03-03 10:08:20.333002 (2.1 minutes) and wrote 5531 records for MESH22_FUT_CME | 2022-03-03 10:08:23.936
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2022-03-03 16:08:20.333002 | 2022-03-03 10:08:23.937
Added 94 Time and Sales records to Intraday data file for MESH22_FUT_CME after download. | 2022-03-03 10:08:23.937
HD Request # 5 | Completion time: 1s | 2022-03-03 10:08:23.937
HD Request # 5 | Intraday data download complete for MESH22_FUT_CME. Unique request ID: 5 | 2022-03-03 10:08:23.937
Removing historical data download ID 5. | 2022-03-03 10:08:23.937
Real-time Intraday chart data file updates started for MESH22_FUT_CME | 2022-03-03 10:08:23.937
Intraday chart data file opened for MESH22_FUT_CME | 2022-03-03 10:08:23.937
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2022-03-03 10:08:23.937
Triggering next historical data download in queue. | 2022-03-03 10:08:23.937
No download requests in the queue to start downloads for. | 2022-03-03 10:08:23.937
Socket (5) | Socket gracefully closed by remote side. | 2022-03-03 10:08:24.082
Socket (5) | Closed. | 2022-03-03 10:08:24.082
Chart #3 has tagged chart #2 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.278
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.278
Chart #3 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.278
MESH22_FUT_CME [CV][M] 2000 Trades #4 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.295
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.321
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.345
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:08:24.349 *
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.481
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.481
Chart #1 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.481
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.487
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:08:24.492 *
MESH22_FUT_CME [CV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.618
MESH22_FUT_CME [CV][M] 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.770
Chart #3 has tagged chart #2 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.786
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.786
Chart #3 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.786
MESH22_FUT_CME [CV][M] 2000 Trades #4 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.796
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.823
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:24.845
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:08:24.849 *
MESH22_FUT_CME [CV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 10:08:25.052
Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\MESH22_FUT_CME.scid. Thread ID: 5208 | 2022-03-03 10:08:27.942
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-03-03 10:10:26.172
DTC Client socket (2) | Closed. | 2022-03-03 10:10:26.172
DTC Client socket (2) | Deleting network socket now after delay. | 2022-03-03 10:10:56.172
Saved Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht. Time: 0.0782 seconds. | 2022-03-03 10:30:35.638
Saved Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht. Time: 0.0820 seconds. | 2022-03-03 10:31:40.082
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:37:59.011
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:37:59.033 *
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:38:20.114
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:38:20.135 *
Saved Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht. Time: 0.0833 seconds. | 2022-03-03 10:38:35.510
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:49:37.227
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:49:37.251 *
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:50:00.441
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:50:00.462 *
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:55:53.313
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:55:53.333 *
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-03-03 10:56:04.690
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 10:56:04.711 *
DTC Client socket (4) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 11:07:44.683 *
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-03-03 11:07:44.683
DTC Client socket (4) | CloseSocket call. | 2022-03-03 11:07:44.684
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-03-03 11:07:44.684
DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 11:07:44.684
DTC Client socket (4) | Closed. | 2022-03-03 11:07:44.684
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:07:44.684
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 11:07:44.684
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:07:44.684
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-03-03 11:07:46.702
DTC Client socket (3) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 11:07:47.810 *
DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-03-03 11:07:47.810
DTC Client socket (3) | CloseSocket call. | 2022-03-03 11:07:47.810
DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 11:07:47.810
SC Data - All Services | Waiting for socket receive thread to end | 2022-03-03 11:07:47.810
DTC Client socket (3) | Closed. | 2022-03-03 11:07:47.810
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:07:47.811
SC Data - All Services | Disconnected from the server. | 2022-03-03 11:07:47.811
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:07:47.811
SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 443 | 2022-03-03 11:07:49.812
DTC Client socket (1) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2022-03-03 11:07:52.197 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-03-03 11:07:52.197
DTC Client socket (1) | CloseSocket call. | 2022-03-03 11:07:52.197
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-03-03 11:07:52.197
DTC Client socket (1) | Max send buffer size during socket life: 235 | 2022-03-03 11:07:52.197
Connection to the external service has been lost. | 2022-03-03 11:07:52.197
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-03-03 11:07:52.197
DTC Client socket (1) | Closed. | 2022-03-03 11:07:52.197
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-03-03 11:07:52.223
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:07:52.223
Teton CME Order Routing | Disconnected. | 2022-03-03 11:07:52.223
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:07:52.223
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-03 11:07:54.230
DTC Client socket (4) | Using previously cached IP address because unable to resolve domain name | 2022-03-03 11:07:57.758
DTC Client socket (4) | Creating socket. | 2022-03-03 11:07:57.758
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-03-03 11:07:57.758
DTC Client socket (4) | Connecting to IP: 204.15.197.13. | 2022-03-03 11:07:57.758
DTC Client socket (2) | Creating socket. | 2022-03-03 11:07:57.759
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 11:07:57.759
DTC Client socket (2) | Connecting to IP: 64.38.174.178. | 2022-03-03 11:07:57.759
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 11:08:04.906
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 11:08:04.906
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-03 11:08:04.906
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:18.788 *
DTC Client socket (4) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:18.788 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 11:08:18.788
DTC Client socket (4) | CloseSocket call. | 2022-03-03 11:08:18.788
DTC Client socket (2) | Closed. | 2022-03-03 11:08:18.789
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:08:18.789
SC Data - All Services | Disconnected from the server. | 2022-03-03 11:08:18.789
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:08:18.789
DTC Client socket (4) | Closed. | 2022-03-03 11:08:18.789
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 11:08:18.789
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:08:18.789
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2022-03-03 11:08:20.788
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-03-03 11:08:20.788
DTC Client socket (2) | Creating socket. | 2022-03-03 11:08:20.789
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 11:08:20.789
DTC Client socket (2) | Connecting to IP: 64.38.174.178. | 2022-03-03 11:08:20.789
DTC Client socket (3) | Creating socket. | 2022-03-03 11:08:20.789
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 11:08:20.789
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-03 11:08:20.789
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:25.936 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 11:08:25.949
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 11:08:25.949
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:08:25.949
DTC Client socket (1) | Closed. | 2022-03-03 11:08:25.949
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:08:25.979
Teton CME Order Routing | Disconnected. | 2022-03-03 11:08:25.979
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:08:25.979
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11093 | 2022-03-03 11:08:28.024
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-03-03 11:08:28.024
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-03-03 11:08:28.024
DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-03-03 11:08:28.024
DTC Client socket (2) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:41.812 *
DTC Client socket (3) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:41.813 *
DTC Client socket (2) | CloseSocket call. | 2022-03-03 11:08:41.813
DTC Client socket (3) | CloseSocket call. | 2022-03-03 11:08:41.813
DTC Client socket (2) | Closed. | 2022-03-03 11:08:41.813
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:08:41.813
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 11:08:41.813
DTC Client socket (3) | Closed. | 2022-03-03 11:08:41.813
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:08:41.813
SC Data - All Services | Disconnected from the server. | 2022-03-03 11:08:41.813
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-03-03 11:08:41.813
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-03-03 11:08:43.833
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-03-03 11:08:43.834
DTC Client socket (1) | Creating socket. | 2022-03-03 11:08:44.070
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 11:08:44.070
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-03-03 11:08:44.070
DTC Client socket (2) | Creating socket. | 2022-03-03 11:08:44.070
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-03-03 11:08:44.070
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-03-03 11:08:44.070
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-03-03 11:08:44.312
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-03-03 11:08:44.312
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 11:08:44.312
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-03-03 11:08:44.587
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-03-03 11:08:44.587
SC DTC Delayed Exchange Data | Received logon response. | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Successfully connected. | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MCLJ22_FUT_CME -> MCLJ22 | 2022-03-03 11:08:45.516
SC DTC Delayed Exchange Data | Received security definition for symbol MCLJ22_FUT_CME | 2022-03-03 11:08:45.958
DTC Client socket (4) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:08:49.045 *
DTC Client socket (4) | CloseSocket call. | 2022-03-03 11:08:49.045
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 11:08:49.045
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:08:49.045
DTC Client socket (4) | Closed. | 2022-03-03 11:08:49.045
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:08:49.061
Teton CME Order Routing | Disconnected. | 2022-03-03 11:08:49.061
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:08:49.061
Teton CME Order Routing | Connecting to the server futurestrading1.sierracharts.com. Port 11093 | 2022-03-03 11:08:51.060
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2022-03-03 11:08:51.322
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-03-03 11:08:51.323
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-03-03 11:08:51.323
File >> Disconnect selected. | 2022-03-03 11:08:55.963
DTC Client socket (3) | CloseSocket call. | 2022-03-03 11:08:55.963
DTC Client socket (3) | Closed. | 2022-03-03 11:08:55.963
DTC Client socket (1) | CloseSocket call. | 2022-03-03 11:08:55.963
SC Data - All Services | Disconnected from the server. | 2022-03-03 11:08:55.963
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-03-03 11:08:55.963
DTC Client socket (1) | Closed. | 2022-03-03 11:08:55.963
DTC Client socket (2) | CloseSocket call. | 2022-03-03 11:08:55.963
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-03-03 11:08:55.963
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-03-03 11:08:55.963
Teton CME Order Routing | Disconnected. | 2022-03-03 11:08:55.963
Teton CME Order Routing | Connecting to the server futurestrading1.sierracharts.com. Port 11092 | 2022-03-03 11:08:57.647
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 11:08:57.647
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 11:08:57.647
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-03-03 11:08:57.647
DTC Client socket (1) | Connect event error. Windows error code 10060: Se produjo un error durante el intento de conexión ya que la parte conectada no respondió adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexión establecida ya que el host conectado no ha podido responder. | 2022-03-03 11:09:18.664 *
DTC Client socket (1) | CloseSocket call. | 2022-03-03 11:09:18.664
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-03 11:09:18.665
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:09:18.665
DTC Client socket (1) | Closed. | 2022-03-03 11:09:18.665
DTC Client socket (0) | CloseSocket call. | 2022-03-03 11:09:18.679
Teton CME Order Routing | Disconnected. | 2022-03-03 11:09:18.679
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-03 11:09:18.679
Teton CME Order Routing | Connecting to the server futurestrading7.sierracharts.com. Port 11092 | 2022-03-03 11:09:20.677
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-03-03 11:09:23.864
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-03-03 11:09:23.864
DTC Client socket (1) | Connecting to IP: 38.89.235.129. | 2022-03-03 11:09:23.864
Teton CME Order Routing | Network connection to server complete. | 2022-03-03 11:09:26.993
Teton CME Order Routing | Starting socket receive thread. | 2022-03-03 11:09:26.993
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-03-03 11:09:26.993
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-03-03 11:09:27.385
Teton CME Order Routing | Sending logon request message. | 2022-03-03 11:09:27.386
Teton CME Order Routing | Received logon response. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Server Name: SC DTC Server. Build=41200. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 11:09:27.975
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Trading is supported. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Order cancel and replace is supported. | 2022-03-03 11:09:27.975
Teton CME Order Routing | OCO Orders supported. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Bracket Orders supported. | 2022-03-03 11:09:27.975
Teton CME Order Routing | Connected to server complete. | 2022-03-03 11:09:27.975
Triggering next historical data download in queue. | 2022-03-03 11:09:27.976
Updated verified funded futures trading account ending date to: 2022-04-02 17:09:27 | 2022-03-03 11:09:27.976
No download requests in the queue to start downloads for. | 2022-03-03 11:09:27.993
Mapping MESH22_FUT_CME to MESH22. Service code: cme | 2022-03-03 11:09:28.016
Using symbol data fast lookup vector | 2022-03-03 11:09:28.016
SC Data - All Services | Starting real-time market data updates for: MESH22_FUT_CME (MESH22). ID: 1 Service code: cme | 2022-03-03 11:09:28.016
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-03-03 11:09:28.016
SC Data - All Services | Requesting security definition data for: MESH22_FUT_CME (MESH22). ID: 1 | 2022-03-03 11:09:28.016
Added historical Intraday data request for MESH22_FUT_CME to the queue. | 2022-03-03 11:09:28.016
Intraday data recording state for symbol MESH22_FUT_CME is set to download 'Pending'. | 2022-03-03 11:09:28.016
Triggering next historical data download in queue. | 2022-03-03 11:09:28.016
DTC Client socket (4) | Creating socket. | 2022-03-03 11:09:28.016
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-03-03 11:09:28.016
DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2022-03-03 11:09:28.016
Delaying start of download for MESH22_FUT_CME | 2022-03-03 11:09:28.028
Updated verified funded futures trading account ending date to: 2022-04-02 17:09:28 | 2022-03-03 11:09:28.116
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH22_FUT_CME | 2022-03-03 11:09:28.139
Teton CME Order Routing | Received security definition for symbol MESH22_FUT_CME | 2022-03-03 11:09:28.139
SC Data - All Services | Network connection to server complete. | 2022-03-03 11:09:28.153
SC Data - All Services | Starting socket receive thread. | 2022-03-03 11:09:28.153
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 11:09:28.153
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-03-03 11:09:28.315
SC Data - All Services | Sending logon request message. | 2022-03-03 11:09:28.315
Mapping ESH22_FUT_CME to ESH22. Service code: cme | 2022-03-03 11:09:28.577
SC Data - All Services | Starting real-time market data updates for: ESH22_FUT_CME (ESH22). ID: 2 Service code: cme | 2022-03-03 11:09:28.577
SC Data - All Services | Requesting security definition data for: ESH22_FUT_CME (ESH22). ID: 2 | 2022-03-03 11:09:28.577
Mapping MCLJ22_FUT_CME to MCLJ22. Service code: nymex | 2022-03-03 11:09:28.577
SC DTC Delayed Exchange Data | Starting real-time market data updates for: MCLJ22_FUT_CME (MCLJ22). ID: 3 Service code: nymex | 2022-03-03 11:09:28.577
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-03-03 11:09:28.577
SC DTC Delayed Exchange Data | Requesting security definition data for: MCLJ22_FUT_CME (MCLJ22). ID: 3 | 2022-03-03 11:09:28.577
DTC Client socket (5) | Creating socket. | 2022-03-03 11:09:28.578
DTC Client socket (5) | New receive buffer size: 5242880 | 2022-03-03 11:09:28.578
DTC Client socket (5) | Connecting to IP: 216.1.90.129. | 2022-03-03 11:09:28.578
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22_FUT_CME | 2022-03-03 11:09:28.700
Teton CME Order Routing | Received security definition for symbol ESH22_FUT_CME | 2022-03-03 11:09:28.700
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-03-03 11:09:28.718
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-03-03 11:09:28.718
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-03-03 11:09:28.719
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-03-03 11:09:28.915
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-03-03 11:09:28.915
SC Data - All Services | Received logon response. | 2022-03-03 11:09:29.190
SC Data - All Services | Server Name: SC Realtime Server. | 2022-03-03 11:09:29.190
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 11:09:29.190
SC Data - All Services | Successfully connected. | 2022-03-03 11:09:29.190
SC Data - All Services | Trading is not supported. | 2022-03-03 11:09:29.190
SC Data - All Services | Restarting real-time data updates for symbol: ESH22_FUT_CME -> ESH22 | 2022-03-03 11:09:29.190
SC Data - All Services | Restarting real-time data updates for symbol: MESH22_FUT_CME -> MESH22 | 2022-03-03 11:09:29.190
SC Data - All Services | Received security definition for symbol ESH22_FUT_CME | 2022-03-03 11:09:29.411
SC Data - All Services | Received security definition for symbol MESH22_FUT_CME | 2022-03-03 11:09:29.411
SC DTC Delayed Exchange Data | Received logon response. | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Successfully connected. | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MCLJ22_FUT_CME -> MCLJ22 | 2022-03-03 11:09:29.613
SC DTC Delayed Exchange Data | Received security definition for symbol MCLJ22_FUT_CME | 2022-03-03 11:09:29.851
Requesting market depth updates for: MESH22_FUT_CME if supported. | 2022-03-03 11:09:32.975
SC Data - All Services | Market Depth data has been rejected for symbol: MESH22_FUT_CME. Not authorized for market depth. | 2022-03-03 11:09:33.133
HD Request # 6 | Downloading Intraday chart data for MESH22_FUT_CME to the file MESH22_FUT_CME.scid. Service: cme | 2022-03-03 11:09:34.641
HD Request # 6 | Download start date-time: 2022-03-03 11:07:18.000000. File last date-time: 2022-03-03 11:07:18.979001 | 2022-03-03 11:09:34.641
HD Request # 6 | Using server: ds23.sierracharts.com port 10149 | 2022-03-03 11:09:34.641
Socket (3) | Creating socket. | 2022-03-03 11:09:34.641
Socket (3) | New receive buffer size: 5242880 | 2022-03-03 11:09:34.641
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-03-03 11:09:34.641
HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-03-03 11:09:34.928
HD Request # 6 | Sending historical data logon request message. | 2022-03-03 11:09:34.929
HD Request # 6 | Requesting Intraday data. Start date-time: 2022-03-03 11:07:18. Record interval: 0. Symbol: MESH22 | 2022-03-03 11:09:35.512
HD Request # 6 | Decompressing data. | 2022-03-03 11:09:35.663
HD Request # 6 | Receiving Intraday data for MESH22_FUT_CME starting at 2022-03-03 11:07:18.515000 | 2022-03-03 11:09:35.941
Socket (3) | CloseSocket call. | 2022-03-03 11:09:35.942
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-03 11:09:35.942
Historical data download thread signaled to stop. | 2022-03-03 11:09:35.942
HD Request # 6 | Timestamp of first Intraday data file record written: 2022-03-03 11:07:19.506000 | 2022-03-03 11:09:35.942
HD Request # 6 | Received 3161 Intraday data records from 2022-03-03 11:07:18.515000 to 2022-03-03 11:09:32.017000 (2.2 minutes) and wrote 3152 records for MESH22_FUT_CME | 2022-03-03 11:09:35.942
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-03-03 17:09:32.017000 | 2022-03-03 11:09:35.943
Added 14 Time and Sales records to Intraday data file for MESH22_FUT_CME after download. | 2022-03-03 11:09:35.943
HD Request # 6 | Completion time: 1s | 2022-03-03 11:09:35.943
HD Request # 6 | Intraday data download complete for MESH22_FUT_CME. Unique request ID: 6 | 2022-03-03 11:09:35.943
Removing historical data download ID 6. | 2022-03-03 11:09:35.943
Real-time Intraday chart data file updates started for MESH22_FUT_CME | 2022-03-03 11:09:35.943
Intraday chart data file opened for MESH22_FUT_CME | 2022-03-03 11:09:35.943
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-03-03 11:09:35.943
Triggering next historical data download in queue. | 2022-03-03 11:09:35.943
No download requests in the queue to start downloads for. | 2022-03-03 11:09:35.943
Chart #3 has tagged chart #2 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.024
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.024
Chart #3 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.024
MESH22_FUT_CME [CV][M] 2000 Trades #4 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.037
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.063
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.075
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.075
Chart #1 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.075
Socket (3) | Socket gracefully closed by remote side. | 2022-03-03 11:09:36.081
Socket (3) | Closed. | 2022-03-03 11:09:36.081
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.082
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 11:09:36.086 *
MESH22_FUT_CME [CV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.273
MESH22_FUT_CME [CV][M] 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.522
Chart #3 has tagged chart #2 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.557
Chart #3 has tagged chart #4 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.557
Chart #3 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.557
MESH22_FUT_CME [CV][M] 2000 Trades #4 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.569
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.595
MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.614
Chart: MESH22_FUT_CME [CV][M] Aligned Renko 5t #5 | Study: Anchor VWAP Study | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2022-03-03 11:09:36.618 *
MESH22_FUT_CME [CV][M] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Fob MES wQB DOM Teton Mar2022 H2 V1.cht | 2022-03-03 11:09:36.773
Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\MESH22_FUT_CME.scid. Thread ID: 5208 | 2022-03-03 11:09:38.926
[2022-03-03 17:47:02]
John - SC Support - Posts: 47994
We see a lot of these errors in your log:
DTC Client socket (2) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.
These indicate a network issue of some kind. Refer to the information at the following link:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
[2022-03-03 18:08:24]
You definitely have connectivity issues from your location. We also see this:
That should not happen at all. And that is an issue on your side with DNS.
Another possibility is your ISP is throttling or degrading data transmission on certain ports. Find out from your ISP if there is any problem with using these ports: 11093 or 11092
