Date/Time: Sun, 27 Sep 2026 20:02:30 +0000
[User Discussion] - connect to MT4
View Count: 4058
| [2022-03-02 12:39:02] |
| william bolger - Posts: 29 |
I read a bunch of threads but no definitive answer. Can we trade on MT4 through SC? |
| [2022-03-02 13:16:06] |
| 1+1=10 - Posts: 270 |
MT4/MT5 is used by Forex/CFD brokers. The only forex brokers that SC supports are Interactive Brokers and LMAX. But if you used either of them thereād be no reason to include MT4/5 in the loop. However, because both SC and MT4/5 have APIs a programmer could probably: 1. Have SC running in sim mode. 2. When trades are entered on sim they could be written to a file in a few milliseconds. 3. The MT4 program could read that file every few milliseconds to see if any new trades had been taken in SC and actually submit those trades in MT4. Thus, with the help of a programmer you could do this. A list of seeming active SC-related programmers is here: 1. https://www.simplesystemtrading.com/?link=x (active -- here's his twitter: https://twitter.com/sstfrederik) 2. https://www.fiverr.com/synergy0911/create-any-trading-code-for-ninjatrader-tradingview-mt4 (it says SC ACSIL in as profile when you scroll down) 3. https://www.upwork.com/freelancers/~01e7a1b7a2edd4853a/ 4. https://forgivingcomputers.com/ Date Time Of Last Edit: 2022-03-02 13:16:46
| [2022-03-02 13:18:42] |
The official answer from Sierra Chart is no in response to post #1.
| [2022-03-21 05:02:53] |
| Colby Stoker - Posts: 31 |
There is a bridge between the two platforms. It is a challenge to work with. Google it.
| [2022-04-05 05:06:49] |
| User888583 - Posts: 20 |
Hi, take a look at AimFx bridge. It allows to copy trades between multiple platforms including sierra chart to mt4. https://aimfx.io/ In case you need more information, let me know. Lukasz / AimFX Date Time Of Last Edit: 2022-04-05 17:37:25
| [2022-06-10 10:57:39] |
| Albamail - Posts: 29 |
Hi All To Sierra Chart Engineering: An MT5 connector would allow SC to be used to analyze markets that SC or compatible providers do not have data for. For example MOEX. And there would be enough willing. |
| [2025-12-04 17:14:38] |
| User673128 - Posts: 4 |
These guys have a trade copier that copies from Sierra Chart to MetaTrader 5 https://www.toptrades.live/trade_copier_sierrachart.html |
| [2026-02-27 17:12:59] |
| Eranox - Posts: 41 |
Hi all, I have fount this bridge: https://github.com/NelsonCaGar/MT5-SierraChart-Connector?tab=readme-ov-file#readme Has anyone tried it if it works? I'm founding a way to trade with Sierrachart on MT5 and Activtrades Thanks Date Time Of Last Edit: 2026-02-27 17:16:34
