Date/Time: Tue, 04 Nov 2025 07:39:41 +0000
MYSTERIOs CHART NAME change of my 5mt CHART of my CHaartBOOK
View Count: 569
|   [2022-02-28 18:53:53]     |
| User427561 - Posts: 217 |
                EVERSINCE I STARTed using SC, my chart book consisted of the 1 and 5 minutes of the emini S&P and defined as FUSEPH22 1m #1 aND 5m #9 respectively. Recently I've been making many modifications in my 1 and 5 minutes charts including adding or deleting studies ibcluding many chart overlays fron the 1 to5 mt charts or 5 to 1. Rencently however I noticed the chart heading of of my 5 min chart changed to FUSEPH22RENKO4ty #9, from its usual heading of the 5 mt chart as FUSEPH225m #9 without the RENKO mention and without noticing which specific addition or deletion of a study originated this change I did not ever had anything to do with Renko studies, and wonder if you can explain this addition to my 5 min chart header of my chartbook, and whether I could reliably depend on that name change in my future overlays of some 5 min charts into my 1min charts FYI I did not notice any particuar change of the 5 mt chart behaviour caused by the change of its labelling at the top  |
|   [2022-02-28 19:25:40]     |
| John - SC Support - Posts: 42737 |
                Go to Chart >> Chart Settings and see what the timeframe of your chart is set to. It looks like it changed to Renko somehow. You would just need to change it back to the correct timeframe you want. If it is changed, then keep in mind that it is possible to change the timeframe through the keyboard, and this may have occurred by accident. Refer to the following: Changing Chart Bars Period: Fast Changing by Keyboard For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
