Date/Time: Fri, 07 Mar 2025 00:52:39 +0000
How do I get this data from symbol type?
View Count: 575
[2022-02-21 19:21:38] |
77sx7 - Posts: 16 |
I currently use symbol service F.US.EPH22 Im looking to use ESH22-CME Im utterly confused. Maybe I set something up wrong? I would greatly appreciate assistance. Thanks in advance. |
[2022-02-21 20:43:59] |
John - SC Support - Posts: 38467 |
They are the same instrument. The difference in the names is due to how different order routing/trading services setup their own symbols. F.US.EPH22 for example, is a CQG symbol for the S&P 500 e-Mini traded on the CME Exchange. Therefore, if you are using CQG to make your trades, then you need to leave the symbol as F.US.EPH22. If you change it, then you will not be able to trade it. Note that if you change your trading service (change the entry in Global Settings >> Data/Trade Service Settings >> Current Selected Service) then you will need to update the symbols in your chartbooks. You can do this by opening the chartbooks and then selecting Edit >> Translate Symbols to Current Service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-21 23:23:19] |
77sx7 - Posts: 16 |
Ok thank you Is the ESH22-CME format a denali routing? |
[2022-02-22 17:00:11] |
Sierra_Chart Engineering - Posts: 18672 |
That symbol is used with SC Data-All Services.
[2022-02-22 19:09:01] |
77sx7 - Posts: 16 |
When I select SC Data-All Service, it works in SIM, but if placed in a live environment it automatically goes to SIM? I would like to use in Live environment. Is that possible?
[2022-02-23 17:18:04] |
Who is your broker and do you know what order routing service they have you setup to use?
