Date/Time: Sun, 09 Mar 2025 00:52:08 +0000
Trade Activity Log displays data only if the end date is Today
View Count: 560
[2022-02-21 00:06:12] |
User888593 - Posts: 9 |
Just updated SC from 2348 to 2361. I have been running bar-based back tests for weeks without issue. Immediately after updating, Trade Activity Log will display non-zero data only if the Today box is checked or the To date is the current date. I have made no changes other than the update. Thanks for the help. |
[2022-02-21 00:10:35] |
See: Important Information About Timestamping (Date-Time) Change in Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-21 00:34:25] |
I saw that thread before creating my thread, but I thought it was a different issue. As far as I can tell from the thread to which you linked, there is no solution at this time. Is that correct?
[2022-02-22 01:47:55] |
Sierra_Chart Engineering - Posts: 18693 |
No that is not correct. If you use version 2361 , look at the Transaction Date-Time field in the Trade Activity Log for the actual true time of the transaction.
[2022-02-22 02:27:37] |
I meant that there is no solution for entering a To date. Because as I explained, results appear only when Today is checked, or the last trade date is entered. I need to parse the data, so I need to enter different To dates.
[2022-02-22 12:43:33] |
ForgivingComputers.com - Posts: 1021 |
I have two problems with the change to the Trade Activity log. 1. DateTime column has always had the transaction date and time, which for Replay and Backtest is critical. Now it is way off to the right where it cannot be viewed along other useful columns like Order Action Source and Internal Order ID. This necessitates copying the log to Excel and manipulating the spreadsheet to see the data together. 2. The Date Range to Display seems to only display the system time, which is useless for backtesting. Why not keep the transaction date/time in the old location and put system DateTime out in right field? This would make things more like they were and not break things in the process. |
[2022-02-22 14:42:22] |
1. The columns can be reordered. In the next release, the new transaction Date-Time column will be on the left. 2. We do see an issue with this and will think about a solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-28 12:10:45] |
2. A solution has been implemented to this. Update to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
