Date/Time: Fri, 02 Oct 2026 16:23:23 +0000
DrawText (winapi) problem in sc.p_GDIFunction, possible bug.
View Count: 1480
[2022-02-18 19:44:16]
User978306 - Posts: 4
Hi, Support.
Trying to create text output at MainPriceGraph, but can not..
Sample SierraChart study:
void  draw_text_function(HWND hwnd, HDC hdc, SCStudyInterfaceRef sc);
SCSFExport scsf_draw_text_test(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    sc.GraphName = "draw text test";
    sc.UpdateAlways = 1;
    sc.AutoLoop = 0;
    sc.GraphRegion = 0;
    sc.p_GDIFunction = draw_text_function;
    return;
  RECT rc;
  ::GetClientRect(hwnd, &rc);
  ::InflateRect(&rc, -300, -300);
  int old_mode = ::SetMapMode(hdc, MM_TEXT);
  TCHAR font_face[] = "Consolas";
  long font_height = -MulDiv(18, ::GetDeviceCaps(hdc, LOGPIXELSY), 72);
  HFONT font = ::CreateFontA(font_height, 0, 0, 0,
    FW_SEMIBOLD, 0, 0, 0, ANSI_CHARSET, OUT_TT_PRECIS, CLIP_DEFAULT_PRECIS,
    DEFAULT_QUALITY, FF_DONTCARE | DEFAULT_PITCH, font_face);
  if (font == nullptr)
    sc.AddMessageToLog("Create study font operatoin error!", 1);
  HGDIOBJ old_font = ::SelectObject(hdc, font);
  std::stringstream ss;
  ss.str("test output string");
  int old_bk_mode = ::SetBkMode(hdc, TRANSPARENT);
  ::SetTextColor(hdc, RGB(255, 0, 0));
  int result = ::DrawTextA(hdc, ss.str().c_str(),
    (int)ss.str().length(), &rc, DT_VCENTER | DT_CENTER | DT_SINGLELINE);
  HPEN pen = ::CreatePen(PS_SOLID, 1, RGB(204, 204, 204));
  ::SelectObject(hdc, ::GetStockObject(NULL_BRUSH));
  HGDIOBJ old_pen = ::SelectObject(hdc, pen);
  Rectangle(hdc, rc.left, rc.top, rc.right, rc.bottom);
  ::DeleteObject(font);
  ::DeleteObject(pen);
  ::SetBkMode(hdc, old_bk_mode);
  ::SelectObject(hdc, old_font);
  ::SelectObject(hdc, old_pen);
  ::SetMapMode(hdc, old_mode);
First attachment contains screenshot of chart with applied study, can see empty rectangle only.
For check, I have created a template VS windows application project and placed inside WM_PAINT block absolutely same code from draw_text_function , have a correct output, can be found in second attachment.
Code:
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message)
case WM_COMMAND:
int wmId = LOWORD(wParam);
// Parse the menu selections:
switch (wmId)
case IDM_ABOUT:
DialogBox(hInst, MAKEINTRESOURCE(IDD_ABOUTBOX), hWnd, About);
break;
case IDM_EXIT:
DestroyWindow(hWnd);
break;
default:
return DefWindowProc(hWnd, message, wParam, lParam);
break;
case WM_PAINT:
PAINTSTRUCT ps;
HDC hdc = BeginPaint(hWnd, &ps);
            RECT rc;
            GetClientRect(hWnd, &rc);
            WCHAR lpsz_face[] = L"Consolas";
            long font_height = -MulDiv(26, ::GetDeviceCaps(hdc, LOGPIXELSY), 72);
            HFONT font = ::CreateFontW(font_height, 0, 0, 0,
              CLEARTYPE_NATURAL_QUALITY, FF_DONTCARE | DEFAULT_PITCH, lpsz_face);
            std::wstringstream ss;
            ss << L"sample text output";
            int result = ::DrawTextW(hdc, (LPWSTR)ss.str().c_str(), (int)ss.str().length(),
              &rc, DT_CENTER| DT_VCENTER | DT_SINGLELINE);
            Rectangle(hdc, rc.left,rc.top,rc.right,rc.bottom);
EndPaint(hWnd, &ps);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return 0;
imagefirst_attachment.png / V - Attached On 2022-02-18 19:38:28 UTC - Size: 14.29 KB - 340 views
imagesecond_attachment.png / V - Attached On 2022-02-18 19:40:57 UTC - Size: 32.57 KB - 337 views
[2022-02-20 11:46:09]
Sierra_Chart Engineering - Posts: 25028
We have looked into this. Refer to the code example below. Use ::TextOutW.
In the next release of Sierra Chart it will also solve a problem where an exception was occurring when unloading a study DLL which has a custom drawing function.
Also take note of the new placement for;
sc.p_GDIFunction = DrawToChart;
#include "sierrachart.h"
// SCDLLName("GDI Example")
// This file demonstrates the functionality to use the Windows Graphics Device
// Interface (GDI) with ACSIL to freely draw inside of the chart window
// Windows GDI documentation can be found here:
// http://msdn.microsoft.com/en-nz/library/windows/desktop/dd145203%28v=vs.85%29.aspx
// Drawing function declaration
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc);
SCSFExport scsf_DrawToChartExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Draw To Chart Example";
    sc.AutoLoop = 0;
    return;
  // This is where we specify the drawing function. This function will be called
  // when the study graph is drawn on the chart. We are placing this after
  // if (sc.SetDefaults). So in case the study DLL is unloaded and reloaded,
  // this will continue to be set to the correct address.
// This is the actual drawing function. This function is specified by the
// "sc.p_GDIFunction" member in the main study function above. This drawing
// function is called when Sierra Chart draws the study on the chart. This
// will only occur after there has been a call to the main "scsf_" study
// function which is defined above.
// This drawing function has access to the ACSIL "sc." structure.
// However, any changes to the variable members will have no effect.
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc )
  //Create a Yellow brush
  HBRUSH Brush = CreateSolidBrush(RGB(255,255,0));
  //Select the brush into the device context
  HGDIOBJ PriorBrush = SelectObject(DeviceContext, Brush);
  //Draw a rectangle at the top left of the chart
  Rectangle(DeviceContext, sc.StudyRegionLeftCoordinate + 5, sc.StudyRegionTopCoordinate + 5, sc.StudyRegionLeftCoordinate + 200, sc.StudyRegionTopCoordinate + 200);
  int RightCoordinate = sc.StudyRegionRightCoordinate;
  //Remove the brush from the device context and put the prior brush back in. This is critical!
  SelectObject(DeviceContext,PriorBrush);
  //Delete the brush. This is critical! If you do not do this, you will end up with
  // a GDI leak and crash Sierra Chart.
  DeleteObject(Brush);
  ::SetTextAlign(DeviceContext, TA_NOUPDATECP);
  //Must use the wide character version
  ::TextOutW(DeviceContext, 250, 250, L"Hello.", 6);
  return;
Date Time Of Last Edit: 2022-02-20 11:49:17
