Date/Time: Mon, 10 Mar 2025 02:10:36 +0000
Cannot use TPO chart since I get errors.
View Count: 784
[2022-02-17 15:06:35]
User795631 - Posts: 17
I cannot use TPO chart, it freezes and get a Caught an unhandled exception in c_Chart::WindowProc Message 15
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61493
[2022-02-17 16:11:12]
John - SC Support - Posts: 38516
Start Sierra Chart in "Safe Mode" and try to put on the TPO study and see if you get the same error. If you do not get the error, then there must be a 3rd party study that is on a chart that is causing the error and you would need to find that particular study.
If you do still have the error show up, then get us the chartbook that is having this issue and let us know what chart you are having the problem with. Follow these instructions to get us your Chartbook:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2022-02-17 23:37:23]
If you still have an issue try disabling the OpenGL option:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
[2022-02-25 04:48:55]
Still have the same issue.
Here is the chartbook attached
attachmentTPO.Cht - Attached On 2022-02-25 04:48:21 UTC - Size: 15.65 KB - 215 views
[2022-02-28 15:52:47]
Sierra_Chart Engineering - Posts: 18722
We are unable to reproduce that WM_PAINT related exception with your Chartbook. Who is the provider of the video drivers on your system? Nvidia, AMD, or Intel?
Not that we can do anything about this, But we would like to know.
Date Time Of Last Edit: 2022-02-28 15:53:02
[2022-03-01 01:18:59]
NVIDIA 1080TI
[2022-03-01 01:19:44]
Usually happens around 12:30 PST or 12:45 PST
[2022-03-11 02:21:30]
Any updates?
[2022-03-11 02:28:43]
The problem persists even after creating a fresh TPO charts with no special studies or indicators also Open GL is unchecked
[2022-03-13 22:38:27]
We are able to reproduce this. We are determining what the problem is.
Date Time Of Last Edit: 2022-03-13 22:42:32
[2022-03-13 22:41:50]
Problem persists after turning Open GL.
[2022-03-13 22:42:15]
Date Time Of Last Edit: 2022-03-13 22:42:22
[2022-03-14 00:00:16]
We have discovered the problem. It is fixed. At least we fixed the exception issue. There may be another issue which needs to be resolved.
We are putting out a new release before morning.
Date Time Of Last Edit: 2022-03-14 00:00:50
[2022-03-14 12:30:10]
Is there a new updated release
[2022-03-14 12:36:09]
Yes it is version 2368. It is a prerelease. Instructions to update:
