Date/Time: Thu, 06 Mar 2025 22:30:49 +0000
can a DOM price ladder be detached from a specific chart?
View Count: 722
[2022-02-16 15:19:04] |
User846472 - Posts: 5 |
can a DOM price ladder be detached from a chart and moved about on the screen can a DOM for the MES be used with ES charts |
[2022-02-16 17:05:24] |
John - SC Support - Posts: 38466 |
Yes and no. There is not a way to specifically remove the DOM ladder from a chart, but there is the standalone Trading DOM that can be opened by selecting either File >> Open Trading DOM or File >> Open Trading DOM for Chart. Refer to the information here: File Menu: Open Trading DOM for Chart (File) can a DOM for the MES be used with ES charts
This is another Yes and No answer. You can open an ES chart and then set the Trade and Current Quote Symbol to the MES symbol. This will then give you the quote and Bid/Ask data for the MES in that chart. Refer to the information here: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
