Date/Time: Sun, 09 Mar 2025 00:57:42 +0000
Interactive broker data
View Count: 892
[2022-02-13 02:27:25]
User250581 - Posts: 22
Hello
i am fairly new to Sierra chart, i started using SC in conjunction with Interactive brokers a couple of months ago. Recently i subscribed to Package 5 and i noticed that when i connect to SC through Interactive broker the data feed is so sluggish to the point that my numbers chart are completely useless.to mitigate this problem i subscribed to sierra chart data feed but found no help because whenever i connect the data is delayed. So finally today i subscribed to package 11 ( includes Denali Data Feed)in hopes to solve this problem. Can you guide me if i need to do any other things in order to improve this slow data feed.
Regards
[2022-02-13 10:32:30]
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
[2022-02-15 21:34:11]
I’m mainly trading NQ, MNQ, Es MES and would also like to get into currency futures in near future. Is Denali Data feed the one that comes with package 11 good enough? And also do I always have to open TWS or there’s alternative way. Thanks.
[2022-02-16 10:27:30]
Therefore, you will need to activate this exchange:
CME non-professional top-of-book
Here:
Yes definitely.
There is an alternative and it is explained here:
Date Time Of Last Edit: 2022-02-16 10:27:59
[2022-02-17 05:24:04]
[2022-02-22 19:25:46]
I activated CME non-proffesional top of book but still no improvements. Whenever i log in all my numbers bars-bid and ask (order flow) show zero, it only starts to fill with numbers after im logged in for a minute or so but nothing before that ( no historical numbers) I troubleshooted in all possible ways but nothing is helping.
[2022-02-22 19:38:22]
Right now i have package 11 + sc data+ cme top of the book, is there any other things to improve the bad slow data feed i'm getting? in another word is there a way i can sign up for market data from sierra chart only while i can still be connected to interactive broker as my execution broker? If im doing any thing wrong with data subscription please let me know Im willing to deactivate every thing and start fresh if needed. Thanks.
[2022-02-23 17:29:35]
John - SC Support - Posts: 38516
It sounds like you are not getting the data from the Denali Exchange Data Feed for some reason. We would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-02-23 21:59:02]
I found the solution from previous post and I finally got the problem fixed. Basically i just needed to go to File> Data/trade services setting>common setting> check "yes" Allow support for sierra chart data. Now I'm getting SC real data feed.
