Date/Time: Fri, 07 Mar 2025 01:18:07 +0000
[Programming Help] - Horizontal Line/Ray on TPO Chart but only for current day?
View Count: 706
[2022-02-11 01:44:35]
amazayn - Posts: 48
I currently have a bunch of levels that I am watching that I have used Horizontal Lines to draw on my TPO chart. As you can see in the attached drawing titled TPO Chart with Levels, this ends up taking alot of real estate on the screen. I'd like to use the Horizontal Ray but I was wondering if there if anyway to get it to only show for the current RTH/ETH session or maybe even one day prior rather (if you look at the attached image titled What i would like to have), you will be able to see what I am referring to.
Thank you
Private File
Private File
[2022-02-11 16:31:35]
John - SC Support - Posts: 38467
The Horizontal Ray is going to start wherever you place the first point and then draw out to the end of the screen in the other direction. So you have control over where it starts, but not where it ends.
The only way to control the start and end would be to use a line. You can hold the 'Ctrl' key when drawing a line to force it to be horizontal.
[2022-02-18 20:52:25]
amazayn - Posts: 48
Is there a way to select more than one horizontal ray at a time on a specific chart. i have mutiple drawings on my chart but i have like 10 horizontal rays that i want to select only them, and update their anchor.
[2022-02-18 21:41:10]
The only thing you can do with multiple drawings is to "Adjust" them (change their price levels/Anchor Prices). You can do this from the "Manage Chart Drawings Window". Refer to the following:
Chart Drawing Tools: Manage Chart Drawings
[2022-02-21 14:17:00]
amazayn - Posts: 48
Thank u so much for this info. But when I chnage my drawing type to Horizontal Ray (bc those are the ones I want to adjust), and then select more then one, I can't select Properties (it gets disabled). How would I change the anchor then?
[2022-02-21 16:32:46]
You can only adjust the drawings by selecting them in the Tools >> Manage Chart Drawings window and then selecting the Adjust button on that window.
[2022-02-21 16:35:27]
amazayn - Posts: 48
Ok, but adjust only allows you to Adjust Amount. There is nothing to change ur Anchor date and time for multiple drawings at once?
[2022-02-21 17:50:58]
Correct. That is the only option available to modify multiple drawings at the same time.
