Date/Time: Wed, 27 Nov 2024 18:33:12 +0000
DOM's lagging during high volume
View Count: 1170
[2022-02-10 16:40:14]
benikeli - Posts: 10
I have an Intel Xeon processor, 12GB of RAM and a SSD drive where only SierraChart and two other programs are installed.
During periods of high volatility and volume, my DOM's and Time & Sales lag. The lag lasts around a second. I have 4 DOM's up (NQ, ES, RTY, YM) and Time & Sales for NQ.
I have no charts up.
Chart update interval is set to 20ms. I use Delayed Data Feed.
I tried reinstalling SierraChart without luck. The problem was worse on HDD, that's why I recently upgraded to SSD but the problem still persists.
I want to have a smooth DOM experience without any pauses. What to do?
Thank you!
[2022-02-10 16:49:48]
Refer to the information here:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM
[2022-02-11 13:58:14]
I have my other DOM's in sub instances, but now I can't recenter them anymore by using a hotkey. How do I fix this?
[2022-02-11 14:36:26]
Does the re-centering function as you expect when using this command:
Trade Menu: Re-Center Trade DOM Scales (Trade menu)
[2022-02-11 16:07:05]
No, except when all DOM's are in the same instance. In my case, each DOM is in a separate instance, they don't re-center.
[2022-02-16 14:53:18]
DOM's still lag sometimes during high volume, even if each DOM is in a separate instance. I have the newest version of Sierra Chart.
[2022-02-16 15:16:09]
Yes this will be true:
First the data you are already receiving is delayed:
Therefore, we need to understand are you noticing an increase in the delay, or is the Chart or Trading DOM, seem sluggish?
Date Time Of Last Edit: 2022-02-16 15:16:29
[2022-02-16 15:27:29]
The DOM's freeze for a couple of seconds or less when there's a high amount of volume (many trades taking place, like at open) at a particular moment. They are smooth when there's low volume and the market is not very busy (like at noon).
The data feed is delayed 10 min as usual but sluggish/laggy as described above.
Date Time Of Last Edit: 2022-02-16 15:28:51
[2023-07-08 23:50:47]
ProfitableTrader - Posts: 22
Hello, Did you get a resolution for this problem? I'm also experiencing the same issue with multiple DOMS from multiple Sierra Chart processes. No Charts open.
