Date/Time: Sun, 13 Sep 2026 17:31:35 +0000
Trouble getting MBO and Denali total ask/pull functionality to work with my Cqg account.
View Count: 1044
[2022-02-07 22:54:45]
User271659 - Posts: 15
Hi guys, last night activated to package 12 for full functionality of the Denali feed for MBO and total Ask/Bid stacking. Today I still had the crappy total stacking from cqg and no MBO orders . I tried everything. Went over the documentation etc.
When i select SC data trade it works fine to see all the levels for pulling/stacking for the micro MESH22 along with MBO's and other symbols. The problem is I am unable to execute trades as it would switch to sim. So today i had to use cqg data to trade without the benefit of the high end Denali feed. Any input would be appreciated. Thanks.
Am i also correct the first month is free for Denali as well?
[2022-02-08 16:24:10]
John - SC Support - Posts: 47854
Your account is all setup properly to get the Denali data.
If you are still having an issue, then be sure your service is set to CQG and then get us your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2022-02-11 13:20:10]
Good morning John here is the message log. Current symbol is f.us.eph22. Hopefully we can figure this out.
Software version: 2353 64-bit | 2022-02-11 08:09:39.312
Primary Thread ID: 7100 | 2022-02-11 08:09:39.312
Usage end date: 2022-03-10 | 2022-02-11 08:09:39.312
Enabled for: Advanced Features 2. | 2022-02-11 08:09:39.312
Enabled for: Sierra Chart Historical Data Service. | 2022-02-11 08:09:39.312
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-11 08:09:39.312
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-11 08:09:39.312
Enabled for exchange2: CME (Trading Account Required) | 2022-02-11 08:09:39.312
Enabled for exchange2: CBOT (Trading Account Required) | 2022-02-11 08:09:39.312
Enabled for exchange2: COMEX (Trading Account Required) | 2022-02-11 08:09:39.312
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-02-11 08:09:39.312
Enabled for exchange2: fairx_exchange.data | 2022-02-11 08:09:39.312
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-11 08:09:39.312
Current selected Data/Trading service: CQG WebAPI | 2022-02-11 08:09:39.312
Custom symbol settings values: enabled | 2022-02-11 08:09:39.312
Chart Update Interval: 500 | 2022-02-11 08:09:39.312
Intraday Data Storage Time Unit: 0 | 2022-02-11 08:09:39.312
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-11 08:09:39.312
2022-02-11 13:09:39 Local computer time in UTC | 2022-02-11 08:09:39.312
2022-02-11 08:09:39 Local computer time in SC Time Zone | 2022-02-11 08:09:39.312
2022-02-11 02:23:03 Server time in UTC | 2022-02-11 08:09:39.312
Local computer UTC time and Server UTC time difference: 4 seconds. | 2022-02-11 08:09:39.312
Program path: C:\SierraChart\ | 2022-02-11 08:09:39.312
Data Files path: C:\SierraChart\Data\ | 2022-02-11 08:09:39.312
OS Version Number: 10.0 | 2022-02-11 08:09:39.313
Locale Setting: C | 2022-02-11 08:09:39.314
DLLs: UserContributedStudies_64.dll | 2022-02-11 08:09:39.314
Allowed protected custom studies: | 2022-02-11 08:09:39.314
File >> Disconnect selected. | 2022-02-11 08:09:45.972
CQG WebAPI | Sending Web API Logoff message. | 2022-02-11 08:09:45.972
CQG WebSocket socket (3) | CloseSocket call. | 2022-02-11 08:09:45.972
CQG WebSocket | WebSocket closed. | 2022-02-11 08:09:45.972
CQG WebAPI | WebSocket closed. | 2022-02-11 08:09:45.972
SC Data - All Services | Waiting for socket receive thread to end | 2022-02-11 08:09:45.973
CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-11 08:09:45.973
DTC Client socket (4) | CloseSocket call. | 2022-02-11 08:09:45.974
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-11 08:09:45.974
SC Data - All Services | Disconnected from the server. | 2022-02-11 08:09:45.974
CQG WebAPI | Disconnected. | 2022-02-11 08:09:45.974
CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2022-02-11 08:09:46.013
CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-11 08:09:46.013
CQG WebAPI | Connecting to server api.cqg.com | 2022-02-11 08:09:57.314
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-02-11 08:09:57.315
CQG WebSocket socket (5) | Creating socket. Using TLS 1.2. | 2022-02-11 08:09:57.316
CQG WebSocket socket (5) | New receive buffer size: 5242880 | 2022-02-11 08:09:57.316
CQG WebSocket socket (5) | Connecting to IP: 208.48.16.35. | 2022-02-11 08:09:57.316
CQG WebSocket | Opening WebSocket. | 2022-02-11 08:09:57.360
CQG WebSocket | Sending WebSocket handshake. | 2022-02-11 08:09:57.360
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-11 08:09:57.491
CQG WebSocket | Server header | Connection: upgrade | 2022-02-11 08:09:57.491
CQG WebSocket | Server header | Sec-WebSocket-Accept: 1Ts1B4vlUoFi1cbCgGZN61DofAk= | 2022-02-11 08:09:57.491
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-02-11 08:09:57.491
CQG WebSocket | Server header | Upgrade: websocket | 2022-02-11 08:09:57.491
CQG WebSocket | Server header | | 2022-02-11 08:09:57.491
CQG WebSocket | Web socket state is now open. | 2022-02-11 08:09:57.491
CQG WebAPI | WebSocket connected. | 2022-02-11 08:09:57.491
CQG WebAPI | Sending market data logon message. | 2022-02-11 08:09:57.491
CQG WebAPI | Base Time: 2022-01-23T06:53:30. 2022-01-23 06:53:30 | 2022-02-11 08:09:57.659
CQG WebAPI | Logon successful. Session Token = iocV/oGciLiPrEvXYDvUUfV8lwYh/pZ/SrhON8WgtEE7lJlgsS6+H3uaawuqCmooaYD8G+d4nKr | 2022-02-11 08:09:57.659
CQG WebAPI | Connected to server complete. | 2022-02-11 08:09:57.659
Triggering next historical data download in queue. | 2022-02-11 08:09:57.660
Updated verified funded futures trading account ending date to: 2022-03-13 13:09:57 | 2022-02-11 08:09:57.661
CQG WebAPI | Sending Trade Accounts request message. | 2022-02-11 08:09:57.661
No download requests in the queue to start downloads for. | 2022-02-11 08:09:57.661
CQG WebAPI | Brokerage name: AMP. Account Name: 102839 | 2022-02-11 08:09:57.749
Updated verified funded futures trading account ending date to: 2022-03-13 13:09:57 | 2022-02-11 08:09:57.749
CQG WebAPI | Sending collateral subscribe request. | 2022-02-11 08:09:57.750
Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-02-11 08:09:58.129
Using symbol data fast lookup vector | 2022-02-11 08:09:58.129
SC Data - All Services | Starting real-time market data updates for: F.US.EPH22 (ESH22). ID: 1 Service code: cme | 2022-02-11 08:09:58.129
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-02-11 08:09:58.129
CQG WebAPI | Sending symbol resolution request for F.US.EPH22. ID: 854125 | 2022-02-11 08:09:58.130
SC Data - All Services | Requesting security definition data for: F.US.EPH22 (ESH22). ID: 1 | 2022-02-11 08:09:58.130
Added historical Intraday data request for F.US.EPH22 to the queue. | 2022-02-11 08:09:58.130
Intraday data recording state for symbol F.US.EPH22 is set to download 'Pending'. | 2022-02-11 08:09:58.130
Triggering next historical data download in queue. | 2022-02-11 08:09:58.130
Delaying start of download for F.US.EPH22 | 2022-02-11 08:09:58.156
CQG WebAPI | Received symbol resolution report for symbol F.US.EPH22. Search Symbol: F.US.EPH22. Request ID: 854125. Contract ID: 1. | 2022-02-11 08:09:58.179
DTC Client socket (6) | Creating socket. | 2022-02-11 08:09:58.198
DTC Client socket (6) | New receive buffer size: 5242880 | 2022-02-11 08:09:58.199
DTC Client socket (6) | Connecting to IP: 208.185.224.129. | 2022-02-11 08:09:58.199
SC Data - All Services | Network connection to server complete. | 2022-02-11 08:09:58.241
SC Data - All Services | Starting socket receive thread. | 2022-02-11 08:09:58.241
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-02-11 08:09:58.241
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-02-11 08:09:58.303
SC Data - All Services | Sending logon request message. | 2022-02-11 08:09:58.303
SC Data - All Services | Received logon response. | 2022-02-11 08:09:59.085
SC Data - All Services | Server Name: SC Realtime Server. | 2022-02-11 08:09:59.085
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-02-11 08:09:59.085
SC Data - All Services | Successfully connected. | 2022-02-11 08:09:59.085
SC Data - All Services | Trading is not supported. | 2022-02-11 08:09:59.085
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH22 -> ESH22 | 2022-02-11 08:09:59.085
SC Data - All Services | Received security definition for symbol F.US.EPH22 | 2022-02-11 08:09:59.211
CQG WebAPI | Sending positions subscribe request. RequestID: 854126 | 2022-02-11 08:10:00.659
CQG WebAPI | Sending orders subscribe request. RequestID: 854127 | 2022-02-11 08:10:00.660
Requesting market depth updates for: F.US.EPH22 if supported. | 2022-02-11 08:10:02.658
SC Data - All Services | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-02-11 08:10:02.658
SC Data - All Services | Clearing market depth for F.US.EPH22 | 2022-02-11 08:10:02.785
HD Request # 46 | Downloading Intraday chart data for F.US.EPH22 to the file F.US.EPH22.scid. Service: cme | 2022-02-11 08:10:04.827
HD Request # 46 | Download start date-time: 2022-02-11 08:09:43.000000. File last date-time: 2022-02-11 08:09:43.661000 | 2022-02-11 08:10:04.829
HD Request # 46 | Using server: ds23.sierracharts.com port 10150 | 2022-02-11 08:10:04.829
Socket (7) | Creating socket. | 2022-02-11 08:10:04.830
Socket (7) | New receive buffer size: 5242880 | 2022-02-11 08:10:04.830
Socket (7) | Connecting to IP: 216.1.90.130. | 2022-02-11 08:10:04.830
HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-02-11 08:10:04.917
HD Request # 46 | Sending historical data logon request message. | 2022-02-11 08:10:04.917
HD Request # 46 | Requesting Intraday data. Start date-time: 2022-02-11 08:09:43. Record interval: 0. Symbol: ESH22 | 2022-02-11 08:10:05.443
HD Request # 46 | Decompressing data. | 2022-02-11 08:10:05.531
HD Request # 46 | Receiving Intraday data for F.US.EPH22 starting at 2022-02-11 08:09:43.661000 | 2022-02-11 08:10:05.534
Socket (7) | CloseSocket call. | 2022-02-11 08:10:05.536
Socket (7) | Shutdown started. Waiting for graceful close. | 2022-02-11 08:10:05.537
Historical data download thread signaled to stop. | 2022-02-11 08:10:05.537
HD Request # 46 | Timestamp of first Intraday data file record written: 2022-02-11 08:09:43.801000 | 2022-02-11 08:10:05.537
HD Request # 46 | Received 132 Intraday data records from 2022-02-11 08:09:43.661000 to 2022-02-11 08:09:59.605000 (15.9 seconds) and wrote 131 records for F.US.EPH22 | 2022-02-11 08:10:05.538
HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2022-02-11 13:09:59.605000 | 2022-02-11 08:10:05.553
Added 3 Time and Sales records to Intraday data file for F.US.EPH22 after download. | 2022-02-11 08:10:05.553
HD Request # 46 | Completion time: 1s | 2022-02-11 08:10:05.553
HD Request # 46 | Intraday data download complete for F.US.EPH22. Unique request ID: 46 | 2022-02-11 08:10:05.553
Removing historical data download ID 46. | 2022-02-11 08:10:05.553
Real-time Intraday chart data file updates started for F.US.EPH22 | 2022-02-11 08:10:05.553
Intraday chart data file opened for F.US.EPH22 | 2022-02-11 08:10:05.553
HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-02-11 08:10:05.553
Triggering next historical data download in queue. | 2022-02-11 08:10:05.553
No download requests in the queue to start downloads for. | 2022-02-11 08:10:05.553
Socket (7) | Socket gracefully closed by remote side. | 2022-02-11 08:10:05.574
Socket (7) | Closed. | 2022-02-11 08:10:05.574
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPH22.scid. Thread ID: 4700 | 2022-02-11 08:10:08.228
CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-11 08:11:29.355
CQG WebSocket socket (1) | Closed. | 2022-02-11 08:11:29.355
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-11 08:11:29.355
DTC Client socket (2) | Closed. | 2022-02-11 08:11:29.355
CQG WebSocket socket (1) | Deleting network socket now after delay. | 2022-02-11 08:11:59.356
DTC Client socket (2) | Deleting network socket now after delay. | 2022-02-11 08:11:59.356
CQG WebSocket socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-11 08:11:59.356
CQG WebSocket socket (3) | Closed. | 2022-02-11 08:11:59.356
DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-11 08:11:59.356
DTC Client socket (4) | Closed. | 2022-02-11 08:11:59.356
CQG WebSocket socket (3) | Deleting network socket now after delay. | 2022-02-11 08:12:29.357
DTC Client socket (4) | Deleting network socket now after delay. | 2022-02-11 08:12:29.357
[2022-02-11 14:51:13]
You should be seeing the market depth data. First look at it in the Market Depth Window to see if it is there:
File Menu: Open Market Depth Window (File)
For market by order data, this option must be set to Yes:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#UseSeparateConnectionForMarketByOrderData
Based upon what we see in the log, it is not set that way.
Date Time Of Last Edit: 2022-02-11 14:54:21
