Date/Time: Thu, 06 Mar 2025 16:30:28 +0000
DATA FEEDS DELAIY
View Count: 487
[2022-02-07 15:19:23]
m zamani rad - Posts: 24
Using sierra chart with CQG and AMP Brooker .
After two weeks back to chart as I log in to CQG ,it will only let me see data on 27/1/2022 ,not getting intraday data .I have tried different symbol same result .
I have also contacted AMP Brooker and everything is ok
here is my message log .
THANK YOU
. Software version: 2276 64-bit | 2022-02-07 04:11:19.914
Primary Thread ID: 8652 | 2022-02-07 04:11:19.914
Usage end date: 2022-02-15 | 2022-02-07 04:11:19.914
Enabled for: Advanced Features 2. | 2022-02-07 04:11:19.914
Enabled for: Sierra Chart Historical Data Service. | 2022-02-07 04:11:19.914
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-07 04:11:19.914
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-07 04:11:19.914
Enabled for exchange2: fairx_exchange.data | 2022-02-07 04:11:19.914
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-07 04:11:19.914
Current selected Data/Trading service: CQG WebAPI | 2022-02-07 04:11:19.914
Custom symbol settings values: enabled | 2022-02-07 04:11:19.914
Chart Update Interval: 500 | 2022-02-07 04:11:19.914
Intraday Data Storage Time Unit: 0 | 2022-02-07 04:11:19.914
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-07 04:11:19.914
2022-02-07 09:11:19 Local computer time in UTC | 2022-02-07 04:11:19.914
2022-02-07 04:11:19 Local computer time in SC Time Zone | 2022-02-07 04:11:19.914
2022-02-07 07:40:15 Server time in UTC | 2022-02-07 04:11:19.914
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-02-07 04:11:19.914
Program path: C:\SierraChart\ | 2022-02-07 04:11:19.914
Data Files path: C:\SierraChart\Data\ | 2022-02-07 04:11:19.914
OS Version Number: 10.0 | 2022-02-07 04:11:19.915
Locale Setting: C | 2022-02-07 04:11:19.915
DLLs: UserContributedStudies_64.dll | 2022-02-07 04:11:19.916
Allowed protected custom studies: | 2022-02-07 04:11:19.916
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2022-02-07 04:27:38.388
The message log has been sent to support. | 2022-02-07 04:27:38.388 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2022-02-07 04:27:38.388
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2022-02-07 04:27:38.388
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2022-02-07 04:27:40.037
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2022-02-07 04:27:40.299
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-02-07 04:27:40.299
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-02-07 04:27:40.334
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-02-07 04:27:40.334
[2022-02-07 22:25:06]
John - SC Support - Posts: 38442
You only have the CME with Market Depth for Non-Professional Trading Accounts active on the Denali Exchange Data Feed. So if you are trying to access instruments that are traded on other exchanges (COMEX, NYMEX, or CBOT), then you will not get the data from the Denali Exchange Data Feed for those.
If you are trying to get a CME instrument, then we need more information from your log. Follow these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
