Date/Time: Thu, 06 Mar 2025 13:04:11 +0000
CQG
View Count: 586
[2022-02-04 20:02:37]
User42662 - Posts: 7
Sir,
I have a AMP account . In order to get real time date I set today my service package from SC data all service to CQG WebApi. But a got a message that logon was disabled. Is there a alternative? I asked AMP to change to teton order routing , but they are not able to do that.
I tried tot connect to Interactive broker.But connection also failed.
So what are now my possibilities to get real time data?
Sincerely
Peter de Vos
[2022-02-04 21:54:21]
John - SC Support - Posts: 38425
Due to the CME Group's requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees, you will have to connect to one of your live, funded, futures trading accounts.
The first thing to do is to check with AMP and find out why your CQG account has been disabled. If you can get that account back, then you can connect to your CQG account by following these instructions:
CQG Trading Platform Service: Setup Instructions
If you have an Interactive Brokers account, then you can connect to that in order to validate your non-professional status for the CME Group. To do this, follow these instructions:
Interactive Brokers Trading Service: Setup Instructions
If it turns out that you do not have a funded account any longer, then refer to the following solution as a way to get an account for a relatively low outlay:
Easy Solution to CME Funded Trading Account Requirement
