Date/Time: Tue, 04 Nov 2025 14:57:43 +0000
Reward/Risk Tool Wrong
View Count: 3235
|   [2013-03-22 16:03:13]     |
| fobglobal - Posts: 51 |
                Hi, The R/R tool do not calculate the numbers correctly, please look the attached Image thanks. Date Time Of Last Edit: 2013-03-22 16:03:46
|   [2013-03-22 16:22:23]     |
                We are not clear what it is you are trying to show us. Also, when you post an image, use this method here and no other: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Please be more clear and post a new image. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-22 16:23:06
|   [2013-03-22 16:46:46]     |
                Well, if you look the image, you can see the following info regarding thr RR tool: entry = 1.2990 Stop = 1.2980 difference 9T (instead of 10T) Target = 1.3010 difference 18T (instead of 20T) So R/R: 1.9 which is wrong In summary: Data is wrong(Differences and calculation) I hope It is clearer now. thanks  |
|   [2013-03-22 17:11:38]     |
                 This would have to do with the following settings in Chart >> Chart Settings: Price Display Format (Needs to correspond to the Tick Size) Tick Size (needs to be correct) Adjust Tool Values to Tick Size (make sure this is enabled) Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-03-23 01:07:15]     |
                Everything is as you mentioned above, but no change, same problem Thanks  |
|   [2013-03-23 01:15:36]     |
                Then we need to get a Chartbook from you that contains this chart drawing so we can test it.  The Chartbook needs to contain just the one chart that has this chart drawing.  Please follow these instructions to provide it: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-03-23 12:02:13]     |
                Sending Chartbook with some examples thanks
|   [2013-03-24 21:31:33]     |
                We are going to look into this.
|   [2013-03-24 22:08:51]     |
| joshtrader - Posts: 526 |
                In the spreadsheet study, sometimes the prices are incorrect, like P/L, for example it should be 350.00 and it's 349.9989752 ...  I have seen several numbers this way, so this sounds like it could be related.
|   [2013-03-25 02:58:55]     |
| Al SC Developer - Posts: 434 |
                The drawing issue will be resolved in ver 958, when available
                 Date Time Of Last Edit: 2013-03-25 03:11:43
|   [2013-03-25 03:09:40]     |
You need to change the Number Format of those cells. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetMenu.html#NumberFormat Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-03-25 03:14:51]     |
                As far as I can tell, this will only change the displayed format of the number, so when I reference this number in another calculation, I would still have to use floor/ceiling in order to get the actual correct value.
|   [2013-03-25 03:53:18]     |
                You could do that, or not be concerned about it and just round off the final Calculation by using the Number Format setting.
|   [2013-03-25 12:46:33]     |
                Ok, I will wait for the V958. thanks
