Date/Time: Sun, 27 Sep 2026 11:04:38 +0000
Denali Data feed
View Count: 803
| [2022-02-03 19:55:07] |
| User118163 - Posts: 2 |
Dear Madame or Sir, in the past I got my realtime data from CQG for Eurex and CBOT. Since 16th December I get no more data. Today I booked from you Service Package 12. Did I understand it correct that you invoice the amount therefore directly to my account? What I have to do to get CBOT and EUREX realtime data from Denali Exchange feed? Where can I book to get this both realtime data and how I have to pay it? Can you please explain it to me detailed step by step how I can get the data. Do I have to change any setting on Sierra Chart to see the charts? Many Thanks in advance for your support. Kind Regards |
| [2022-02-03 20:09:57] |
We can provide this data. But if you are already getting it through CQG let us first see what the problem is since you seem to be paying the exchange fees already this month. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-03 20:33:26] |
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-02-03 21:23:23.778 Reading Internal Order ID file. | 2022-02-03 21:23:26.458 Reading Trade Orders file. | 2022-02-03 21:23:27.083 Reading Trade Positions file. | 2022-02-03 21:23:27.116 Reading Trade Account Data files. | 2022-02-03 21:23:27.116 UDPListener (1468). Port 22904 | Listening on UDP port 22904. | 2022-02-03 21:23:27.256 Software version: 2351 64-bit | 2022-02-03 21:23:27.257 Primary Thread ID: 11592 | 2022-02-03 21:23:27.257 Usage end date: 2022-03-11 | 2022-02-03 21:23:27.257 Enabled for: Advanced Features 2. | 2022-02-03 21:23:27.257 Enabled for: Sierra Chart Historical Data Service. | 2022-02-03 21:23:27.257 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-03 21:23:27.257 Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-03 21:23:27.257 Enabled for exchange2: fairx_exchange.data | 2022-02-03 21:23:27.257 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-03 21:23:27.257 Current selected Data/Trading service: DTC Service | 2022-02-03 21:23:27.257 Custom symbol settings values: enabled | 2022-02-03 21:23:27.257 Chart Update Interval: 500 | 2022-02-03 21:23:27.257 Intraday Data Storage Time Unit: 0 | 2022-02-03 21:23:27.257 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2022-02-03 21:23:27.257 2022-02-03 20:23:27 Local computer time in UTC | 2022-02-03 21:23:27.257 2022-02-03 21:23:27 Local computer time in SC Time Zone | 2022-02-03 21:23:27.257 2022-02-03 20:23:17 Server time in UTC | 2022-02-03 21:23:27.257 Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-02-03 21:23:27.257 Program path: C:\SierraChart\ | 2022-02-03 21:23:27.257 Data Files path: C:\SierraChart\Data\ | 2022-02-03 21:23:27.257 OS Version Number: 10.0 | 2022-02-03 21:23:27.257 Locale Setting: C | 2022-02-03 21:23:27.257 DLLs: UserContributedStudies_64.dll | 2022-02-03 21:23:27.272 Allowed protected custom studies: | 2022-02-03 21:23:27.272 Checking for new symbol settings. Requested symbol settings MD5 for service code dtc. Request ID: 1. | 2022-02-03 21:23:27.319 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-02-03 21:23:27.414 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-02-03 21:23:27.414 Received 5 login tokens. | 2022-02-03 21:23:27.551 Symbol settings MD5 received. Request ID: 1. | 2022-02-03 21:23:27.574 Symbol settings are up-to-date for dtc. | 2022-02-03 21:23:27.574 Requesting current DateTime from Sierra Chart server. | 2022-02-03 21:23:27.579 Received Date-time from server. Delay adjusted UTC Date-time: 2022-02-03 20:23:26.911. Round-trip delay: 00:00:00.099 | 2022-02-03 21:23:27.779 Computer time to server time difference: 00:00:00.867 | 2022-02-03 21:23:27.779 Error setting System Date-Time. Windows error code 1314: Dem Client fehlt ein erforderliches Recht. | 2022-02-03 21:23:27.779 * Files to Open on Startup | Opening file: MiniDax.Cht | 2022-02-03 21:23:31.572 F.US.FDXMH22 [CBV] 15 Min #1 | Reloading chart. | 2022-02-03 21:23:31.747 F.US.FDXMH22 [CBV] 15 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:31.747 F.US.FDXMH22 [CBV] 15 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:31.747 F.US.FDXMH22 [CBV] 60 Min #2 | Reloading chart. | 2022-02-03 21:23:31.851 F.US.FDXMH22 [CBV] 60 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:31.851 F.US.FDXMH22 [CBV] 60 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:31.851 F.US.FDXMH22 [CBV] 3 Min #3 | Reloading chart. | 2022-02-03 21:23:31.938 F.US.FDXMH22 [CBV] 3 Min #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:31.938 F.US.FDXMH22 [CBV] 3 Min #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:31.938 F.US.FDXMH22 [CBV] 1 Min #4 | Reloading chart. | 2022-02-03 21:23:32.694 F.US.FDXMH22 [CBV] 1 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:32.694 F.US.FDXMH22 [CBV] 1 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:32.694 Files to Open on Startup | Opening file: MiniDowJones.Cht | 2022-02-03 21:23:32.711 F.US.YMH22 [CBV] 15 Min #1 | Reloading chart. | 2022-02-03 21:23:32.892 F.US.YMH22 [CBV] 15 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:32.892 F.US.YMH22 [CBV] 15 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:32.892 F.US.YMH22 [CBV] 60 Min #2 | Reloading chart. | 2022-02-03 21:23:33.023 F.US.YMH22 [CBV] 60 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:33.023 F.US.YMH22 [CBV] 60 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:33.023 F.US.YMH22 [CBV] 3 Min #3 | Reloading chart. | 2022-02-03 21:23:33.177 F.US.YMH22 [CBV] 3 Min #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:33.177 F.US.YMH22 [CBV] 3 Min #3 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:33.177 F.US.YMH22 [CBV] 1 Min #4 | Reloading chart. | 2022-02-03 21:23:34.111 F.US.YMH22 [CBV] 1 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:34.111 F.US.YMH22 [CBV] 1 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:34.111 F.US.MYMH22 [CBV] 3 Min #5 | Reloading chart. | 2022-02-03 21:23:34.830 F.US.MYMH22 [CBV] 3 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2022-02-03 21:23:34.830 F.US.MYMH22 [CBV] 3 Min #5 | There are no continuous futures contract symbols. Loading data normally. | 2022-02-03 21:23:34.830 F.US.FDXMH22 [CBV-D] 15 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.FDXMH22.scid | 2022-02-03 21:23:34.872 F.US.FDXMH22 [CBV-D] 60 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.FDXMH22.scid | 2022-02-03 21:23:34.876 F.US.FDXMH22 [CBV-D] 3 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.FDXMH22.scid | 2022-02-03 21:23:34.883 F.US.FDXMH22 [CBV-D] 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.FDXMH22.scid | 2022-02-03 21:23:34.893 F.US.YMH22 [CBV-D] 3 Min #3 | StartDateTimeForLoadingOrderFills: 2021-11-24 02:15:00 | 2022-02-03 21:23:35.032 F.US.YMH22 [CBV-D] 1 Min #4 | StartDateTimeForLoadingOrderFills: 2021-11-24 02:17:00 | 2022-02-03 21:23:35.157 DTC Service | Remote address is not set. | 2022-02-03 21:23:35.439 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:35.439 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:35.439 Using symbol data fast lookup vector | 2022-02-03 21:23:35.439 F.US.MYMH22 [CBV-D] 3 Min #5 | StartDateTimeForLoadingOrderFills: 2021-10-18 00:00:00 | 2022-02-03 21:23:35.507 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:35.706 DTC Service | Disconnected. | 2022-02-03 21:23:35.706 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:35.706 DTC Service | Remote address is not set. | 2022-02-03 21:23:37.710 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:37.710 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:37.710 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:37.721 DTC Service | Disconnected. | 2022-02-03 21:23:37.721 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:37.721 DTC Service | Remote address is not set. | 2022-02-03 21:23:39.728 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:39.728 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:39.728 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:39.739 DTC Service | Disconnected. | 2022-02-03 21:23:39.739 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:39.739 DTC Service | Remote address is not set. | 2022-02-03 21:23:41.738 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:41.738 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:41.738 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:41.760 DTC Service | Disconnected. | 2022-02-03 21:23:41.760 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:41.760 DTC Service | Remote address is not set. | 2022-02-03 21:23:43.757 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:43.757 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:43.757 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:43.768 DTC Service | Disconnected. | 2022-02-03 21:23:43.768 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:43.768 DTC Service | Remote address is not set. | 2022-02-03 21:23:45.777 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:45.777 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:45.777 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:45.784 DTC Service | Disconnected. | 2022-02-03 21:23:45.784 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:45.784 DTC Service | Remote address is not set. | 2022-02-03 21:23:47.789 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:47.789 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:47.789 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:47.800 DTC Service | Disconnected. | 2022-02-03 21:23:47.800 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:47.800 DTC Service | Remote address is not set. | 2022-02-03 21:23:49.810 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:49.810 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:49.810 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:49.821 DTC Service | Disconnected. | 2022-02-03 21:23:49.821 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:49.821 DTC Service | Remote address is not set. | 2022-02-03 21:23:51.819 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:51.819 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:51.819 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:51.830 DTC Service | Disconnected. | 2022-02-03 21:23:51.830 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:51.830 DTC Service | Remote address is not set. | 2022-02-03 21:23:53.837 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:53.837 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:53.837 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:53.847 DTC Service | Disconnected. | 2022-02-03 21:23:53.847 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:53.847 DTC Service | Remote address is not set. | 2022-02-03 21:23:55.852 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:55.852 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:55.852 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:55.863 DTC Service | Disconnected. | 2022-02-03 21:23:55.863 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:55.863 DTC Service | Remote address is not set. | 2022-02-03 21:23:57.870 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:57.870 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:57.870 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:57.880 DTC Service | Disconnected. | 2022-02-03 21:23:57.881 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:57.881 DTC Service | Remote address is not set. | 2022-02-03 21:23:59.882 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:23:59.882 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:59.882 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:23:59.903 DTC Service | Disconnected. | 2022-02-03 21:23:59.903 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:23:59.903 DTC Service | Remote address is not set. | 2022-02-03 21:24:01.901 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:01.901 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:01.901 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:01.911 DTC Service | Disconnected. | 2022-02-03 21:24:01.911 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:01.911 DTC Service | Remote address is not set. | 2022-02-03 21:24:03.910 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:03.910 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:03.910 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:03.931 DTC Service | Disconnected. | 2022-02-03 21:24:03.931 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:03.931 DTC Service | Remote address is not set. | 2022-02-03 21:24:05.932 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:05.932 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:05.932 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:05.943 DTC Service | Disconnected. | 2022-02-03 21:24:05.943 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:05.943 DTC Service | Remote address is not set. | 2022-02-03 21:24:07.947 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:07.947 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:07.947 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:07.958 DTC Service | Disconnected. | 2022-02-03 21:24:07.958 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:07.958 DTC Service | Remote address is not set. | 2022-02-03 21:24:09.959 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:09.959 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:09.959 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:09.980 DTC Service | Disconnected. | 2022-02-03 21:24:09.980 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:09.980 DTC Service | Remote address is not set. | 2022-02-03 21:24:11.983 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:11.983 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:11.983 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:11.994 DTC Service | Disconnected. | 2022-02-03 21:24:11.994 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:11.994 DTC Service | Remote address is not set. | 2022-02-03 21:24:13.990 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:13.990 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:13.990 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:14.012 DTC Service | Disconnected. | 2022-02-03 21:24:14.012 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:14.012 DTC Service | Remote address is not set. | 2022-02-03 21:24:16.009 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:16.009 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:16.009 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:16.019 DTC Service | Disconnected. | 2022-02-03 21:24:16.019 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:16.019 DTC Service | Remote address is not set. | 2022-02-03 21:24:18.022 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:18.022 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:18.022 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:18.043 DTC Service | Disconnected. | 2022-02-03 21:24:18.043 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:18.043 DTC Service | Remote address is not set. | 2022-02-03 21:24:20.041 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:20.041 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:20.041 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:20.052 DTC Service | Disconnected. | 2022-02-03 21:24:20.052 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:20.052 DTC Service | Remote address is not set. | 2022-02-03 21:24:22.128 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:22.128 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:22.128 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:22.150 DTC Service | Disconnected. | 2022-02-03 21:24:22.150 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:22.150 DTC Service | Remote address is not set. | 2022-02-03 21:24:24.151 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:24.151 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:24.151 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:24.162 DTC Service | Disconnected. | 2022-02-03 21:24:24.162 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:24.162 DTC Service | Remote address is not set. | 2022-02-03 21:24:26.163 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:26.163 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:26.163 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:26.174 DTC Service | Disconnected. | 2022-02-03 21:24:26.174 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:26.174 DTC Service | Remote address is not set. | 2022-02-03 21:24:28.190 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:28.190 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:28.190 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:28.207 DTC Service | Disconnected. | 2022-02-03 21:24:28.207 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:28.207 DTC Service | Remote address is not set. | 2022-02-03 21:24:30.218 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:30.218 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:30.218 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:30.228 DTC Service | Disconnected. | 2022-02-03 21:24:30.228 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:30.228 DTC Service | Remote address is not set. | 2022-02-03 21:24:32.227 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:32.227 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:32.227 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:32.238 DTC Service | Disconnected. | 2022-02-03 21:24:32.238 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:32.238 DTC Service | Remote address is not set. | 2022-02-03 21:24:34.239 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:34.239 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:34.239 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:34.261 DTC Service | Disconnected. | 2022-02-03 21:24:34.261 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:34.261 DTC Service | Remote address is not set. | 2022-02-03 21:24:36.253 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:36.253 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:36.253 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:36.274 DTC Service | Disconnected. | 2022-02-03 21:24:36.274 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:36.274 DTC Service | Remote address is not set. | 2022-02-03 21:24:38.275 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:38.275 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:38.275 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:38.285 DTC Service | Disconnected. | 2022-02-03 21:24:38.285 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:38.286 DTC Service | Remote address is not set. | 2022-02-03 21:24:40.287 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:40.287 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:40.287 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:40.309 DTC Service | Disconnected. | 2022-02-03 21:24:40.309 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:40.309 DTC Service | Remote address is not set. | 2022-02-03 21:24:42.305 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:42.305 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:42.305 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:42.316 DTC Service | Disconnected. | 2022-02-03 21:24:42.316 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:42.316 DTC Service | Remote address is not set. | 2022-02-03 21:24:44.318 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:44.318 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:44.318 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:44.339 DTC Service | Disconnected. | 2022-02-03 21:24:44.340 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:44.340 DTC Service | Remote address is not set. | 2022-02-03 21:24:46.334 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:46.334 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:46.334 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:46.356 DTC Service | Disconnected. | 2022-02-03 21:24:46.356 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:46.356 DTC Service | Remote address is not set. | 2022-02-03 21:24:48.351 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:48.351 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:48.351 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:48.361 DTC Service | Disconnected. | 2022-02-03 21:24:48.361 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:48.361 DTC Service | Remote address is not set. | 2022-02-03 21:24:50.368 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:50.368 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:50.368 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:50.379 DTC Service | Disconnected. | 2022-02-03 21:24:50.379 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:50.379 DTC Service | Remote address is not set. | 2022-02-03 21:24:52.381 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:52.381 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:52.381 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:52.402 DTC Service | Disconnected. | 2022-02-03 21:24:52.402 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:52.402 DTC Service | Remote address is not set. | 2022-02-03 21:24:54.399 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:54.399 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:54.399 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:54.410 DTC Service | Disconnected. | 2022-02-03 21:24:54.410 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:54.410 DTC Service | Remote address is not set. | 2022-02-03 21:24:56.412 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:56.412 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:56.412 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:56.426 DTC Service | Disconnected. | 2022-02-03 21:24:56.426 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:56.426 DTC Service | Remote address is not set. | 2022-02-03 21:24:58.426 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:24:58.426 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:58.426 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:24:58.448 DTC Service | Disconnected. | 2022-02-03 21:24:58.448 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:24:58.449 DTC Service | Remote address is not set. | 2022-02-03 21:25:00.443 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:00.443 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:00.443 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:00.465 DTC Service | Disconnected. | 2022-02-03 21:25:00.465 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:00.465 DTC Service | Remote address is not set. | 2022-02-03 21:25:02.456 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:02.456 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:02.456 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:02.479 DTC Service | Disconnected. | 2022-02-03 21:25:02.480 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:02.480 DTC Service | Remote address is not set. | 2022-02-03 21:25:04.475 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:04.475 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:04.475 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:04.486 DTC Service | Disconnected. | 2022-02-03 21:25:04.486 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:04.486 DTC Service | Remote address is not set. | 2022-02-03 21:25:06.496 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:06.496 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:06.496 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:06.507 DTC Service | Disconnected. | 2022-02-03 21:25:06.507 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:06.507 DTC Service | Remote address is not set. | 2022-02-03 21:25:08.505 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:08.505 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:08.505 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:08.526 DTC Service | Disconnected. | 2022-02-03 21:25:08.526 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:08.526 DTC Service | Remote address is not set. | 2022-02-03 21:25:10.524 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:10.524 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:10.524 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:10.535 DTC Service | Disconnected. | 2022-02-03 21:25:10.535 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:10.535 DTC Service | Remote address is not set. | 2022-02-03 21:25:12.537 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:12.537 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:12.537 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:12.557 DTC Service | Disconnected. | 2022-02-03 21:25:12.557 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:12.557 DTC Service | Remote address is not set. | 2022-02-03 21:25:14.551 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:25:14.551 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:14.551 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:25:14.573 DTC Service | Disconnected. | 2022-02-03 21:25:14.573 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:25:14.573 DTC Service | Remote address is not set. | 2022-02-03 21:27:14.565 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:27:14.565 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:27:14.565 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:27:14.586 DTC Service | Disconnected. | 2022-02-03 21:27:14.586 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:27:14.586 File >> Disconnect selected. | 2022-02-03 21:27:43.549 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:27:43.549 DTC Service | Disconnected. | 2022-02-03 21:27:43.549 DTC Service | Remote address is not set. | 2022-02-03 21:28:06.280 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:06.280 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:06.280 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:06.290 DTC Service | Disconnected. | 2022-02-03 21:28:06.290 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:06.290 DTC Service | Remote address is not set. | 2022-02-03 21:28:08.287 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:08.287 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:08.287 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:08.308 DTC Service | Disconnected. | 2022-02-03 21:28:08.308 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:08.308 DTC Service | Remote address is not set. | 2022-02-03 21:28:10.303 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:10.303 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:10.303 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:10.325 DTC Service | Disconnected. | 2022-02-03 21:28:10.325 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:10.325 DTC Service | Remote address is not set. | 2022-02-03 21:28:12.323 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:12.323 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:12.323 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:12.333 DTC Service | Disconnected. | 2022-02-03 21:28:12.334 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:12.334 DTC Service | Remote address is not set. | 2022-02-03 21:28:14.333 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:14.333 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:14.333 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:14.354 DTC Service | Disconnected. | 2022-02-03 21:28:14.354 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:14.354 DTC Service | Remote address is not set. | 2022-02-03 21:28:16.352 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:16.352 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:16.352 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:16.363 DTC Service | Disconnected. | 2022-02-03 21:28:16.363 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:16.363 DTC Service | Remote address is not set. | 2022-02-03 21:28:18.367 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:18.367 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:18.367 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:18.378 DTC Service | Disconnected. | 2022-02-03 21:28:18.378 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:18.378 DTC Service | Remote address is not set. | 2022-02-03 21:28:20.385 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:20.385 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:20.385 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:20.395 DTC Service | Disconnected. | 2022-02-03 21:28:20.395 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:20.395 DTC Service | Remote address is not set. | 2022-02-03 21:28:22.396 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:22.396 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:22.396 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:22.417 DTC Service | Disconnected. | 2022-02-03 21:28:22.417 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:22.418 DTC Service | Remote address is not set. | 2022-02-03 21:28:24.414 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:24.414 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:24.414 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:24.424 DTC Service | Disconnected. | 2022-02-03 21:28:24.425 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:24.425 DTC Service | Remote address is not set. | 2022-02-03 21:28:26.428 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:26.428 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:26.428 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:26.450 DTC Service | Disconnected. | 2022-02-03 21:28:26.450 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:26.450 DTC Service | Remote address is not set. | 2022-02-03 21:28:28.446 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:28.446 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:28.446 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:28.462 DTC Service | Disconnected. | 2022-02-03 21:28:28.462 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:28.462 DTC Service | Remote address is not set. | 2022-02-03 21:28:30.458 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:30.458 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:30.458 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:30.474 DTC Service | Disconnected. | 2022-02-03 21:28:30.474 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:30.474 DTC Service | Remote address is not set. | 2022-02-03 21:28:32.473 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:32.473 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:32.473 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:32.494 DTC Service | Disconnected. | 2022-02-03 21:28:32.494 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:32.494 DTC Service | Remote address is not set. | 2022-02-03 21:28:34.494 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:34.494 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:34.494 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:34.504 DTC Service | Disconnected. | 2022-02-03 21:28:34.504 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:34.504 DTC Service | Remote address is not set. | 2022-02-03 21:28:36.509 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:36.509 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:36.509 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:36.519 DTC Service | Disconnected. | 2022-02-03 21:28:36.519 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:36.519 DTC Service | Remote address is not set. | 2022-02-03 21:28:38.526 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:38.526 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:38.526 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:38.537 DTC Service | Disconnected. | 2022-02-03 21:28:38.537 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:38.537 DTC Service | Remote address is not set. | 2022-02-03 21:28:40.538 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:40.538 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:40.538 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:40.559 DTC Service | Disconnected. | 2022-02-03 21:28:40.559 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:40.559 DTC Service | Remote address is not set. | 2022-02-03 21:28:42.555 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:42.555 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:42.555 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:42.566 DTC Service | Disconnected. | 2022-02-03 21:28:42.566 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:42.566 DTC Service | Remote address is not set. | 2022-02-03 21:28:44.566 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:44.566 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:44.566 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:44.587 DTC Service | Disconnected. | 2022-02-03 21:28:44.587 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:44.587 DTC Service | Remote address is not set. | 2022-02-03 21:28:46.585 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:46.585 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:46.585 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:46.606 DTC Service | Disconnected. | 2022-02-03 21:28:46.606 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:46.606 DTC Service | Remote address is not set. | 2022-02-03 21:28:48.597 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:48.597 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:48.597 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:48.619 DTC Service | Disconnected. | 2022-02-03 21:28:48.619 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:48.620 DTC Service | Remote address is not set. | 2022-02-03 21:28:50.615 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:50.615 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:50.615 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:50.637 DTC Service | Disconnected. | 2022-02-03 21:28:50.637 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:50.637 DTC Service | Remote address is not set. | 2022-02-03 21:28:52.633 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:52.633 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:52.633 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:52.644 DTC Service | Disconnected. | 2022-02-03 21:28:52.644 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:52.644 DTC Service | Remote address is not set. | 2022-02-03 21:28:54.655 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:54.655 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:54.655 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:54.666 DTC Service | Disconnected. | 2022-02-03 21:28:54.666 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:54.666 DTC Service | Remote address is not set. | 2022-02-03 21:28:56.661 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:56.661 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:56.661 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:56.683 DTC Service | Disconnected. | 2022-02-03 21:28:56.683 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:56.683 DTC Service | Remote address is not set. | 2022-02-03 21:28:58.678 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:28:58.678 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:58.678 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:28:58.699 DTC Service | Disconnected. | 2022-02-03 21:28:58.699 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:28:58.699 DTC Service | Remote address is not set. | 2022-02-03 21:29:00.697 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:00.697 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:00.697 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:00.708 DTC Service | Disconnected. | 2022-02-03 21:29:00.708 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:00.708 DTC Service | Remote address is not set. | 2022-02-03 21:29:02.709 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:02.709 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:02.709 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:02.730 DTC Service | Disconnected. | 2022-02-03 21:29:02.730 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:02.730 DTC Service | Remote address is not set. | 2022-02-03 21:29:04.724 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:04.724 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:04.724 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:04.745 DTC Service | Disconnected. | 2022-02-03 21:29:04.745 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:04.745 DTC Service | Remote address is not set. | 2022-02-03 21:29:06.739 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:06.740 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:06.740 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:06.761 DTC Service | Disconnected. | 2022-02-03 21:29:06.761 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:06.761 DTC Service | Remote address is not set. | 2022-02-03 21:29:08.759 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:08.759 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:08.759 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:08.770 DTC Service | Disconnected. | 2022-02-03 21:29:08.770 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:08.770 DTC Service | Remote address is not set. | 2022-02-03 21:29:10.775 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:10.775 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:10.775 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:10.786 DTC Service | Disconnected. | 2022-02-03 21:29:10.787 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:10.787 DTC Service | Remote address is not set. | 2022-02-03 21:29:12.788 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:12.788 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:12.788 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:12.799 DTC Service | Disconnected. | 2022-02-03 21:29:12.799 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:12.799 DTC Service | Remote address is not set. | 2022-02-03 21:29:14.807 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:14.807 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:14.807 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:14.818 DTC Service | Disconnected. | 2022-02-03 21:29:14.818 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:14.818 DTC Service | Remote address is not set. | 2022-02-03 21:29:16.817 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:16.817 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:16.817 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:16.839 DTC Service | Disconnected. | 2022-02-03 21:29:16.839 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:16.839 DTC Service | Remote address is not set. | 2022-02-03 21:29:18.834 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:18.834 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:18.834 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:18.855 DTC Service | Disconnected. | 2022-02-03 21:29:18.855 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:18.856 DTC Service | Remote address is not set. | 2022-02-03 21:29:20.850 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:20.850 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:20.850 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:20.872 DTC Service | Disconnected. | 2022-02-03 21:29:20.872 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:20.872 DTC Service | Remote address is not set. | 2022-02-03 21:29:22.868 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:22.868 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:22.868 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:22.879 DTC Service | Disconnected. | 2022-02-03 21:29:22.879 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:22.879 DTC Service | Remote address is not set. | 2022-02-03 21:29:24.880 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:24.880 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:24.880 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:24.902 DTC Service | Disconnected. | 2022-02-03 21:29:24.902 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:24.902 DTC Service | Remote address is not set. | 2022-02-03 21:29:26.899 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:26.899 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:26.899 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:26.909 DTC Service | Disconnected. | 2022-02-03 21:29:26.910 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:26.910 DTC Service | Remote address is not set. | 2022-02-03 21:29:28.909 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:28.909 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:28.909 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:28.930 DTC Service | Disconnected. | 2022-02-03 21:29:28.930 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:28.930 DTC Service | Remote address is not set. | 2022-02-03 21:29:30.929 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:30.929 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:30.929 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:30.950 DTC Service | Disconnected. | 2022-02-03 21:29:30.950 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:30.950 DTC Service | Remote address is not set. | 2022-02-03 21:29:32.946 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:32.946 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:32.946 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:32.957 DTC Service | Disconnected. | 2022-02-03 21:29:32.957 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:32.957 DTC Service | Remote address is not set. | 2022-02-03 21:29:34.962 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:34.962 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:34.962 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:34.973 DTC Service | Disconnected. | 2022-02-03 21:29:34.974 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:34.974 DTC Service | Remote address is not set. | 2022-02-03 21:29:36.976 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:36.976 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:36.976 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:36.987 DTC Service | Disconnected. | 2022-02-03 21:29:36.987 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:36.987 DTC Service | Remote address is not set. | 2022-02-03 21:29:38.991 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:38.991 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:38.991 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:39.002 DTC Service | Disconnected. | 2022-02-03 21:29:39.002 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:39.002 DTC Service | Remote address is not set. | 2022-02-03 21:29:41.008 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:41.008 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:41.008 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:41.018 DTC Service | Disconnected. | 2022-02-03 21:29:41.019 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:41.019 DTC Service | Remote address is not set. | 2022-02-03 21:29:43.022 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:43.022 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:43.022 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:43.043 DTC Service | Disconnected. | 2022-02-03 21:29:43.043 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:43.043 DTC Service | Remote address is not set. | 2022-02-03 21:29:45.038 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:29:45.038 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:45.038 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:29:45.049 DTC Service | Disconnected. | 2022-02-03 21:29:45.049 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:29:45.049 DTC Service | Remote address is not set. | 2022-02-03 21:31:45.064 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 21:31:45.064 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:31:45.064 DTC Client socket (0) | CloseSocket call. | 2022-02-03 21:31:45.075 DTC Service | Disconnected. | 2022-02-03 21:31:45.075 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 21:31:45.075 |
