Date/Time: Thu, 06 Mar 2025 12:52:50 +0000
Cannot Connect
View Count: 461
[2022-02-02 15:19:06]
User489473 - Posts: 10
Dear Support,
I am an user with data feed from TransAct. Today my Sierra Chart platform cannot connect. It always shows "Connecting" and the status bar is in yellow. How to fix it ?
below is the message log:
Reading Internal Order ID file. | 2022-02-01 20:05:43.948
Reading Trade Orders file. | 2022-02-01 20:05:44.001
Reading Trade Positions file. | 2022-02-01 20:05:44.001
Reading Trade Account Data files. | 2022-02-01 20:05:44.002
UDPListener (1524). Port 22903 | Listening on UDP port 22903. | 2022-02-01 20:05:44.023
Software version: 2351 64-bit | 2022-02-01 20:05:44.023
Primary Thread ID: 10820 | 2022-02-01 20:05:44.023
Usage end date: 2022-04-17 | 2022-02-01 20:05:44.023
Enabled for: Sierra Chart Historical Data Service. | 2022-02-01 20:05:44.023
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-01 20:05:44.023
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-01 20:05:44.023
Current selected Data/Trading service: TransAct WS | 2022-02-01 20:05:44.023
Custom symbol settings values: disabled | 2022-02-01 20:05:44.023
Chart Update Interval: 40 | 2022-02-01 20:05:44.023
Intraday Data Storage Time Unit: 0 | 2022-02-01 20:05:44.023
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-01 20:05:44.023
2022-02-02 02:05:44 Local computer time in UTC | 2022-02-01 20:05:44.023
2022-02-01 20:05:44 Local computer time in SC Time Zone | 2022-02-01 20:05:44.023
2022-02-02 02:05:41 Server time in UTC | 2022-02-01 20:05:44.023
Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-02-01 20:05:44.023
Program path: C:\SierraChart\SierraChartTransActMA\ | 2022-02-01 20:05:44.023
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2022-02-01 20:05:44.023
OS Version Number: 10.0 | 2022-02-01 20:05:44.024
Locale Setting: C | 2022-02-01 20:05:44.024
DLLs: Emoji Trading Order Flow Suite.dll, HighVAP_64.dll, OFA Bars (by Zdislav)_64.dll, UserContributedStudies_64.dll, zyp sierra free (2020)_2151_64.dll, zyp sierra free (2020)_64.dll, zyp sierra free_2151_64.dll, zyp sierra free_64.dll | 2022-02-01 20:05:44.024
Allowed protected custom studies: | 2022-02-01 20:05:44.024
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2022-02-01 20:05:44.043
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-02-01 20:05:44.066
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-02-01 20:05:44.367
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-02-01 20:05:44.368
Received 5 login tokens. | 2022-02-01 20:05:45.802
Symbol settings MD5 received. Request ID: 1. | 2022-02-01 20:05:46.372
Requested symbol settings for service code transact.trading. Request ID: 2. | 2022-02-01 20:05:46.372
Symbol settings received. Request ID: 2. | 2022-02-01 20:05:50.152
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-02-01 20:05:51.366
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-02-01 20:05:51.366
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2022-02-01 20:05:51.366
Auth Websocket socket (1) | New receive buffer size: 5242880 | 2022-02-01 20:05:51.366
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2022-02-01 20:05:51.366
Auth Websocket | Opening WebSocket. | 2022-02-01 20:05:51.572
Auth Websocket | Sending WebSocket handshake. | 2022-02-01 20:05:51.572
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-01 20:05:52.158
Auth Websocket | Server header | Upgrade: WebSocket | 2022-02-01 20:05:52.158
Auth Websocket | Server header | Connection: Upgrade | 2022-02-01 20:05:52.158
Auth Websocket | Server header | Sec-WebSocket-Accept: 57flt9pE4AT+r1QvPAYPZmNfjNw= | 2022-02-01 20:05:52.158
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-02-01 20:05:52.158
Auth Websocket | Server header | | 2022-02-01 20:05:52.158
Auth Websocket | Web socket state is now open. | 2022-02-01 20:05:52.158
TransAct WS | Sending account logon message. Simulated Live | 2022-02-01 20:05:52.158
Service connection timed out. Will disconnect and retry. | 2022-02-01 20:06:51.368 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-01 20:06:51.368
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:06:51.368
TransAct WS | Session key cleared | 2022-02-01 20:06:51.384
Auth Websocket socket (1) | CloseSocket call. | 2022-02-01 20:06:51.384
Auth Websocket | WebSocket closed. | 2022-02-01 20:06:51.384
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-01 20:06:51.385
TransAct WS | Disconnected. | 2022-02-01 20:06:51.385
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:06:51.385
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2022-02-01 20:06:51.586
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-02-01 20:06:51.587
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-02-01 20:06:52.386
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-02-01 20:06:52.386
Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2022-02-01 20:06:52.386
Auth Websocket socket (2) | New receive buffer size: 5242880 | 2022-02-01 20:06:52.386
Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2022-02-01 20:06:52.386
Auth Websocket | Opening WebSocket. | 2022-02-01 20:06:52.576
Auth Websocket | Sending WebSocket handshake. | 2022-02-01 20:06:52.576
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-01 20:06:53.175
Auth Websocket | Server header | Upgrade: WebSocket | 2022-02-01 20:06:53.175
Auth Websocket | Server header | Connection: Upgrade | 2022-02-01 20:06:53.175
Auth Websocket | Server header | Sec-WebSocket-Accept: 9MWoRQw7FKtgo5wNoP2QMyFDH8o= | 2022-02-01 20:06:53.175
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-02-01 20:06:53.175
Auth Websocket | Server header | | 2022-02-01 20:06:53.175
Auth Websocket | Web socket state is now open. | 2022-02-01 20:06:53.175
TransAct WS | Sending account logon message. Simulated Live | 2022-02-01 20:06:53.175
Service connection timed out. Will disconnect and retry. | 2022-02-01 20:07:52.392 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-01 20:07:52.392
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:07:52.392
TransAct WS | Session key cleared | 2022-02-01 20:07:52.407
Auth Websocket socket (2) | CloseSocket call. | 2022-02-01 20:07:52.407
Auth Websocket | WebSocket closed. | 2022-02-01 20:07:52.407
TransAct WS | Disconnected. | 2022-02-01 20:07:52.407
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:07:52.407
Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-01 20:07:52.407
Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2022-02-01 20:07:52.607
Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-01 20:07:52.607
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-02-01 20:07:53.417
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-02-01 20:07:53.417
Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2022-02-01 20:07:53.417
Auth Websocket socket (3) | New receive buffer size: 5242880 | 2022-02-01 20:07:53.417
Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2022-02-01 20:07:53.417
Auth Websocket | Opening WebSocket. | 2022-02-01 20:07:53.633
Auth Websocket | Sending WebSocket handshake. | 2022-02-01 20:07:53.633
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-01 20:07:54.262
Auth Websocket | Server header | Upgrade: WebSocket | 2022-02-01 20:07:54.262
Auth Websocket | Server header | Connection: Upgrade | 2022-02-01 20:07:54.262
Auth Websocket | Server header | Sec-WebSocket-Accept: bFID+v78ujyOXC8DniCw1zrqIw4= | 2022-02-01 20:07:54.262
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-02-01 20:07:54.262
Auth Websocket | Server header | | 2022-02-01 20:07:54.262
Auth Websocket | Web socket state is now open. | 2022-02-01 20:07:54.262
TransAct WS | Sending account logon message. Simulated Live | 2022-02-01 20:07:54.262
Service connection timed out. Will disconnect and retry. | 2022-02-01 20:08:53.416 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-01 20:08:53.416
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:08:53.416
TransAct WS | Session key cleared | 2022-02-01 20:08:53.431
Auth Websocket socket (3) | CloseSocket call. | 2022-02-01 20:08:53.431
Auth Websocket | WebSocket closed. | 2022-02-01 20:08:53.431
TransAct WS | Disconnected. | 2022-02-01 20:08:53.431
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:08:53.432
Auth Websocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-01 20:08:53.432
Auth Websocket socket (3) | Write has completed. Shutdown being performed. | 2022-02-01 20:08:53.633
Auth Websocket socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-01 20:08:53.633
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-02-01 20:08:54.438
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-02-01 20:08:54.438
Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2022-02-01 20:08:54.438
Auth Websocket socket (4) | New receive buffer size: 5242880 | 2022-02-01 20:08:54.438
Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2022-02-01 20:08:54.438
Auth Websocket | Opening WebSocket. | 2022-02-01 20:08:54.651
Auth Websocket | Sending WebSocket handshake. | 2022-02-01 20:08:54.651
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-01 20:08:55.264
Auth Websocket | Server header | Upgrade: WebSocket | 2022-02-01 20:08:55.264
Auth Websocket | Server header | Connection: Upgrade | 2022-02-01 20:08:55.264
Auth Websocket | Server header | Sec-WebSocket-Accept: klax6lOlhClycg8g5QQVBC4yDm8= | 2022-02-01 20:08:55.264
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-02-01 20:08:55.264
Auth Websocket | Server header | | 2022-02-01 20:08:55.264
Auth Websocket | Web socket state is now open. | 2022-02-01 20:08:55.264
TransAct WS | Sending account logon message. Simulated Live | 2022-02-01 20:08:55.264
Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-01 20:09:05.735
Auth Websocket socket (1) | Closed. | 2022-02-01 20:09:05.735
Auth Websocket socket (1) | Deleting network socket now after delay. | 2022-02-01 20:09:35.746
Service connection timed out. Will disconnect and retry. | 2022-02-01 20:09:54.429 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-01 20:09:54.429
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:09:54.429
TransAct WS | Session key cleared | 2022-02-01 20:09:54.446
Auth Websocket socket (4) | CloseSocket call. | 2022-02-01 20:09:54.446
Auth Websocket | WebSocket closed. | 2022-02-01 20:09:54.446
TransAct WS | Disconnected. | 2022-02-01 20:09:54.446
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-01 20:09:54.446
Auth Websocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-01 20:09:54.446
Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2022-02-01 20:09:54.656
Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-01 20:09:54.657
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-02-01 20:09:55.447
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-02-01 20:09:55.447
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2022-02-01 20:09:55.448
Auth Websocket socket (1) | New receive buffer size: 5242880 | 2022-02-01 20:09:55.448
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2022-02-01 20:09:55.448
Auth Websocket | Opening WebSocket. | 2022-02-01 20:09:55.661
Auth Websocket | Sending WebSocket handshake. | 2022-02-01 20:09:55.661
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-01 20:09:56.286
Auth Websocket | Server header | Upgrade: WebSocket | 2022-02-01 20:09:56.287
Auth Websocket | Server header | Connection: Upgrade | 2022-02-01 20:09:56.287
Auth Websocket | Server header | Sec-WebSocket-Accept: lqiGtUj60wIPXIXxL6iJLcfPi9U= | 2022-02-01 20:09:56.287
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-02-01 20:09:56.287
Auth Websocket | Server header | | 2022-02-01 20:09:56.287
Auth Websocket | Web socket state is now open. | 2022-02-01 20:09:56.287
TransAct WS | Sending account logon message. Simulated Live | 2022-02-01 20:09:56.287
Auth Websocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-01 20:10:05.748
Auth Websocket socket (2) | Closed. | 2022-02-01 20:10:05.748
[2022-02-02 16:26:15]
This is a Transact server issue that Sierra Chart has no control over. Also please refer to this thread:
*Important* Priority Message to Transact Users
Let us know if you have any further questions.
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
