Date/Time: Thu, 06 Mar 2025 04:22:50 +0000
adding limit orders market depth inof
View Count: 477
[2022-01-27 15:05:11]
User199865 - Posts: 23
Hi when i changed to ryhtmic on my DOM the limit orders bid & offer are now only limited to 1 up and down. Beofre I had 10 limit order info on either side. How do I chagne this back from 1 to 10. Is it something to do with the new symbol? Thanks
[2022-01-27 17:55:26]
John - SC Support - Posts: 38425
You can go through the following to see if there is a setting that you have changed that may have impacted this:
File Menu: Not Receiving the Full Number of Market Depth Levels
But, since you state that this is a change to Rithmic, most likely what you are seeing is just what is being sent by Rithmic, in which case there is nothing that we can do. Refer to the following:
Rithmic Trading Platform Service: Rithmic Support Policy
