Date/Time: Thu, 06 Mar 2025 04:30:35 +0000
How to link a stop order to a limit?
View Count: 506
[2022-01-27 08:29:09]
User485486 - Posts: 43
Hey,
The title may be misleading. I do not mean a normal connection between the orders (oco). I mean I would like to know to make the stop order and the limit order always stays at the same distance automatically. That is, if I change one of them then the other will change accordingly. For example, if the stop was a point away from the entry price, and the limit was also a point away from the entry price, and for some reason I decided to move the stop to a distance of 2 points from the entry price. In normal mode, the limit will still remain a point away from the entrance. I was happy that the limit would also change to a distance of 2 points, at the same time that the stop would change to a distance of 2 points (in other words, that they would be linked in distance).
Thanks!
[2022-01-27 16:13:40]
John - SC Support - Posts: 38425
There is no way to do this within the normal workings of Sierra Chart. You could setup a series of studies that would allow you to modify an offset value in a study and then have that update both the Target and the Stop. But it sounds like you want to be able to modify one of the attached orders manually.
The only way to be able to do this would be to build a custom study. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
Or, if you want to contact a developer, then refer to our list here:
List of Third Party Sierra Chart Study and System Programmers
