Date/Time: Thu, 06 Mar 2025 04:03:16 +0000
Can't Connect
View Count: 613
[2022-01-26 02:50:59]
Michael Jewell - Posts: 2
When attempting to connect to the data feed, the process seems to be stuck in "Connecting". Below is the information in the log...
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-01-25 18:33:25.379
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-01-25 18:33:25.379
Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2022-01-25 18:33:25.379
Auth Websocket socket (4) | New receive buffer size: 5242880 | 2022-01-25 18:33:25.379
Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2022-01-25 18:33:25.379
Auth Websocket | Opening WebSocket. | 2022-01-25 18:33:25.429
Auth Websocket | Sending WebSocket handshake. | 2022-01-25 18:33:25.429
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-01-25 18:33:25.578
Auth Websocket | Server header | Upgrade: WebSocket | 2022-01-25 18:33:25.578
Auth Websocket | Server header | Connection: Upgrade | 2022-01-25 18:33:25.578
Auth Websocket | Server header | Sec-WebSocket-Accept: mJQs45Se0rK9ty9NSthVh/bZZlQ= | 2022-01-25 18:33:25.578
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-01-25 18:33:25.578
Auth Websocket | Server header | | 2022-01-25 18:33:25.578
Auth Websocket | Web socket state is now open. | 2022-01-25 18:33:25.578
TransAct WS | Sending account logon message. Live | 2022-01-25 18:33:25.578
Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-25 18:33:39.377
Auth Websocket socket (1) | Closed. | 2022-01-25 18:33:39.377
Auth Websocket socket (1) | Deleting network socket now after delay. | 2022-01-25 18:34:09.378
File >> Disconnect selected. | 2022-01-25 18:34:24.693
TransAct WS | Session key cleared | 2022-01-25 18:34:24.693
Auth Websocket socket (4) | CloseSocket call. | 2022-01-25 18:34:24.693
Auth Websocket | WebSocket closed. | 2022-01-25 18:34:24.693
TransAct WS | Disconnected. | 2022-01-25 18:34:24.693
Auth Websocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-25 18:34:24.693
Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2022-01-25 18:34:24.740
Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-25 18:34:24.740
Auth Websocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-25 18:34:39.385
Auth Websocket socket (2) | Closed. | 2022-01-25 18:34:39.385
[2022-01-26 04:25:34]
See our response here regarding this:
Cannot Connect To New TransAct Socket | Post: 292781
And also another user had the same problem and see our response here:
Cannot connect to TransAct data feed at 6pm ET now 25Jan2022
[2022-01-26 14:17:31]
Stage 5 Trading - Posts: 155
Dear Trader,
As a former Infinity Broker I fully understand the trials and tribulations of changing brokerage firms. As far as I understand, the Transact connection is in the process of no longer being supported by Sierra Chart. Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. I believe the best overall solution for you would be to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders.
Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current issues.
If you have questions or would like to speak to an assigned personal broker for details, please call us at 312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/
If you are ready to move to the Teton Order Routing solution right away, we invite you to file an application here: https://stage5trading.com/
Thank you,
Anthony Giacomin
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
